1999 Mitsubishi Eclipse GST Convertible
- Ownership Status
- Currently Own
- Year
- 1999
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 20g
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- DSM 6851S aka 68HTA V3
Full turbo back 3 inch exhaust, FP Race Manifold, Upgraded 02 housing. Mishimoto Race Radiator, Factory Fans. NGK iridium plus 8 heat range
- Mods-Engine
- Fully built bottom end - Manley Performance Rotating Assembly. 86mm Pistons x 150mm H-Beam Rods , ACL bearings, ARP hardware. Factory head but with upgraded valves and springs and stock cams.
- Mods-EMS & Logging
- Ecuflash/evoscan
- Mods-Drivetrain
- Upgraded 1st and 2nd gear and full rebuild and a wavetrac limited slip
- Mods-Handling
- Converted to GSX brakes, Koni adjustable's on all 4 corners, Eibach Springs, Upgraded sway bars front and back, poly bushings. Continental Extreme Contact tires on 17's
- Background
- Bought in 2008 as my daily w/130000 miles. Started upgrading on the cheap. As those upgrades failed/wore out started getting more reliable/expensive updates. Started with a Ebay16g upgraded to a ebay 20g when it died. Then just recently upgraded to a FP 68hta v3. Original engine died at 270,000 due to a sudden loss of oil (seal blew on the oil cooler)Locked everything up. Got a new block from a savage yard from a 97 talon I believe. Had it machined and I personally built the bottom end around 2019/2020. Now in 2024 its no longer my daily but my fair weather car, has 310000 miles and a new turbo.
- Dyno HP
- 400 whp
