- Ownership Status
- Currently Own
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 50-trim
- Drivetrain
- AWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- FP E-MANI 3" TURBO BACK THERMAL CAT-BACK EXHAUST FP RED TIAL BOV TIAL 44MM WG P.R. O2 OPEN DUMP 1G TB AEM FUEL RAIL DENSO 720CC WALBRO 400 PUMP
- Mods-Engine
- 6 Bolt Wiseco pistons CP Rods HKS 272 CAMS & GEARS KIGGLY PRESSURE REGULATOR & RACE SPRINGS FERREA VALVES TOPLINE LIFTERS
- Mods-EMS & Logging
- Dsm link V3 AEM wide band Aem boost AEM trans temp AEM 3.5 MAP GM AIT
- Mods-Drivetrain
- KIGGLY CLUTCH PACK
ALTO FINAL GEAR
WELDED DIFF
TRANS LAB SHIFT KIT
SINSTER-SIX TORQUE CONVERTER
- Mods-Handling
- TEIN SUPER FLEX WITH DAMPER DEVICE
FRONT UPPER LOWER FRONT CONTROL ARMS W/ ENERGY SUSPENSION BUSHINGS
ST SWAY BAR WITH SWAY BAR LINKS
3G REAR UPPER AND LOWER CONTROL ARMS W/SWAY BAR AND LINKS
FRONT AND REAR UPPER STRUT MOUNTS SWAY BAR DC SPORTS
TORQUE SOLUTION REAR SUB FRAME BUSHINGS
