- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GSX
- Turbo Type
- 16g
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- VRSF FMIC
FP 68Hta V1
Greddy Bov
Forced Performance exhaust manifold
Forced Performance recirculating intake
NGK7 EIX spark plugs gapped to 0.025
NGK spark plug wires
3 inch megan racing down pipe
3 inch megan racing catback exhaust
O2 dump pipe
Fuelab adjustable fuel pressure regulator set at 43 PSI
Fuel lab fuel filter
FIC fuel rail
FIC 2150cc injectors with resistor delete plug
Walbro 255
STM fuel pump rewire kit
Mishimoto Aluminum Race Radiator
Mishimoto thermostat
Mishimoto slim fans
EVO III Intake Manifold
1G Turbo 60mm Throttle Body
Prothane Motor Mount Inserts
Torque Solution Shifter Cable Bushings
ENERGY M/T SHIFTER BUSHING
JM Fab PC680 Small Battery Kit
- Mods-Engine
- Balance shaft delete
Port and polished Cylinder head
GSC S2 Cams
Kiggly HP Beehive Valve Spring & Titanium Retainers
Kiggly HLA pressure regulator
GSC valves
GSC valve guides with Depth Stopper
Supertech performance valve stems seals
Evo 8 rocker arms
Evo 8 lifters
Fluidampr Performance Engine Damper
ARP Harmonic Balancer Bolt
ARP Crank Pulley Bolt Set: M8 x 1.25 x 35 hex black oxide bolts
ACL/Orbit Oil Pump
Gates water pump
Standard Arp head studs
Cometic MLS Head Gasket (1.3mm)
Wiseco 85mm 10.0:1 HD
Manley turbo tuff I-Beam
Clevite 77 Tri-Metal Rod Bearing Set .50mm
Clevite 77 Tri-Metal Main Bearing Set .25mm
King Thrust Washer Set
- Mods-EMS & Logging
- AEM Truboost
AEM X series wideband
AEM Digital Oil Pressure
V3 ECM link on Speed density (GM-style MAP, IAT)
GM flex fuel sensor
- Mods-Drivetrain
- ACT Flywheel XACT streetlite
ACT pressure plate
ACT clutch solid street
Competition Clutch Fork
ACT Release Bearing
- Mods-Handling
- Tein street basis Z Coilover
