- Ownership Status
- Currently Own
- Year
- 1993
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- DNP t4 tubular manifold** PTE billet t4 6262**PTP Blanket** F38mm TiAL gate** GATES timing belt** TiAL 50mm** ETS 10.5 race FMIC ** Hallman pro MBC** 3" short route piping** Q45 TB,** Venom intake mani** Apexi N1 full 3in cat back with custom heat wrapped down pipe** NGK br7es plugs .18gap** 1450cc fic blue max injectors running e85** Aeromotive A1000 afpr,** Two rewired Walbero 255 lph fuel pumps** -6an feed** fuel lab high flow stainless filter** Stm's 4'' with K&N intake** B&M Oil cooler with braded -10 lines** -12an catch can setup with calan's can.** Mirror black coated and shaved vc with -12 nipples welded on** Carbon fiber spark plug cover**
- Mods-Engine
- Full ported 6bolt head with 3angel Valve job** BC 280/280 camshafts** BC Springs and titanium retainers** AEM adj Cam Gears @ Zero** Weisco 8:5:1 pistons** Eagle Rods With ARP rod bolts** ARP head studs** Cometic mls head gasket** Full prothane engine inserts. Balance shaft removal kit** BLE timing tensioner **
- Mods-EMS & Logging
- **ECM LINK V3/SD with ecmlinks 4bar map** GM FLEX FUEL SENSOR ** LC1 WB/DB blue gauge** Dynatek ARC-2** AEM boost gauge** HKS TT-0** Automeater pyrometer** OIL pres/Water Temp**
- Mods-Drivetrain
- **Shepard stage 4 transmission** Shep clutch pedal assembly** PTT 7.25 high torque plate twin disk** PTT Cone TOB** Full Braided SS clutch line**
- Mods-Handling
- **Ksport pro kit coilovers** Ingalls rear camber kit** Braided and nylon coated brake lines** Brumbo cross drilled rear rotors** Magen racing strut bar** ROTA torque with Nitto NT05 235,40,17** BAER big brake kit 13" rotors**
- Parts Wishlist
- Dents fixed and paint. Slicks on FD wheels.
- 1/4 Mile E/T
- 11.44
- 1/4 Mile MPH
- 132.6
- 1/8 Mile E/T
- 7.644
- 1/8 Mile MPH
- 102.07
- 60' Time
- 2.001
- Timeslip Video Link
- Watch Video
- Timeslip Details
- Low boost, Slow shifting and not launching it.
- Dyno HP
- 624.1 whp
- Dyno TQ
- 500.7 lb/ft
- Dyno Type
- DynoJet
- Dyno Video Link
- Watch Video
- Dyno Shop Name
- MAPerformance
- Dyno Session Details
- 34-35 psi. 6262 e80ish
