Please Support Kiggly Racing
1992 Plymouth Laser RS AWD
Ownership Status
Currently Own
Plymouth Laser RS Turbo AWD
Turbo Type
20g
Drivetrain
AWD
Build Type
  1. Street
FIC 850cc Injectors
Walbro 255 Pump (rewired)
VRSF Front Mount Intercooler
50mm BOV
Aeromotive AFPR
Ebay manual boost controller
20g - Justin Whitesell built
FP cast manifold
3in exhaust
CXracing aluminum radiator
Poly motor mounts
Exhaust blanket
Mods-Engine
272 regrind cams
Fresh bottom end rebuild with Ebay stock pistons
Fresh head rebuilt with new valves, guides, etc.
ARP head studs
ARP rod bolts
ACL Race Main & Rod bearings
OEM balance shaft elimination kit
Mods-EMS & Logging
Megasquirt standalone ECU
Glowshift gauges:
-AFR
-Boost
-Fuel Pressure
-Voltage
-Oil Pressure
-Coolant temp
Mods-Drivetrain
Short Shifter
ACT 2600 Clutch
New KYB shocks
Ebay lowering springs
Videos
Zachary Mears
More in 1G DSM
Share this Vehicle
