For 1990-1999 Mitsubishi Eclipse, Eagle Talon, Plymouth Laser, and Galant VR-4 Owners
  • Join the Community!
Please Support JNZ Tuning
Please Support VR-Speed Factory
Street Build 1992 Lancer 6-bolt VR4 engine
Mitsubishi Galant VR-4
Turbo Type
20g
Drivetrain
FWD
Build Type
  1. Street
Front mount intercooler, 3 inches exhaust, evo 3 exhaust manifold, Turbosmart BOV, magnaflow fuel regulator, magnecor wires, 1000cc ID injectors, walbro fuel pump.
Mods-Engine
Full ported cylinder head, Supertech SS valves stock size, Supertech double springs and bronze valve guides, Kelford 272-272, custom composite head gasket 1.9mm with o-rings, Kiggly racing main girdle and HLA, ACL main and rod bearings, AEM tru-time cam gears, Wiseco 86.5mm HD2 8.5:1 pistons, Manley TT Long rods, MAP H11 head studs, ARP main studs, ARP flywheel bolts.
Mods-EMS & Logging
AEM EMS 2, AEM TRUBOOST, AEM WIDEBAND, AEM IAT, AEM MAP sensor, AEM EGT sensor, Shiftlight.
Mods-Drivetrain
Clutch masters high rev pressure plate with 6 puck disc , fidanza flywheel, Quaife LSD
Koni coil over adjustable
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned VR Speed Factory
mikellinos
Share this Vehicle
