- Ownership Status
- Currently Own
- Year
- 1992
- Model/Trim
- Eagle Talon TSi AWD
- Drivetrain
- AWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- T3 Ramhorn Exhaust Manifold, Hx40 Turbo, .70ar bep housing, 3" custom downpipe to 3” Full Exhaust with Dynoport Muffler. ETS FMIC, 2150cc FIC injectors, Dual 255lph HP Fuel pumps, Mitsu radiator, 1000hp aluminum one piece driveshaft.
- Mods-Engine
- 1G 6 Bolt 4G63 Head, Hot tanked, Milled Ported & Polished, Stage 3 Race Head with 1mm+ oversized stainless steel valves, New Valve Stem seals, NEW oem keepers, GSC Beehive Springs,Ti Retainers, 3G lifters, brass guides, GSC S3 Cams, HKS cam gears
1G 6 Bolt 4G63 Block, Hot tanked, Decked, Line honed main for Kiggly girdle. Bored .020 over, 85.5mm wiseco HD 1400 pistons with Eagle rods. New freeze plugs, New ARP L19 headstuds, New ARP mainstuds, Oem Crank, New oil pan, BSE kit.
- Mods-Drivetrain
- Extremepsi HD one piece aluminum driveshaft, Aftermarket rear sway bar. Fidanza lightweight flywheel XTD Stage 4 clutch with OEM throwout bearing, 4 Bolt rear end.
- Mods-Handling
- D2 coil overs
