  • Join the Community!
    DSMtuners is a massive archive of DSM information - but more importantly, it's a COMMUNITY! Join in and participate with other DSMers, and invite all of your DSM friends to make this place their home. Chat with others, create a build thread, post questions and answers. Get involved! Logging in will also remove many of the advertisements, along with this notice. ;) It will also allow you to view images in threads.
Street Build 1991 Galant VR-4 88/2000
Ownership Status
Currently Own
Mitsubishi Galant VR-4
Drivetrain
AWD
Build Type
  1. Street
INTAKE:
Speed Density
FP 4” air intake
Rebuilt ‘91 throttle body
STM StainlessThrottle Body Elbow
HKS Blow off Valve
FMIC
TURBO:
FP Green UHF 57S
- Compressor - 73HTZ with 52.6MM Inducer / 73MM Exducer + 84MM Flow Advancement Port Cover
- Turbine - FP 8CM With 64MM Inducer / 57MM Exducer - Xona 57s
EXHAUST:
FP Exhaust Manifold Coated
STM stainless o2 housing w/ TiAl wastegate
Megan racing 3” downpipe
Ordered: 3" Fujitsubo Cat Back Exhaust for E39A Galant vr-4
FUEL:
Ethanol sensor
FIC 1440CC High Impedance Injectors
FIC Fuel Rail
Fuel Lab Fuel Pressure Regulator
Fuel Lab Fuel Filter (40 Micron)
Walbro 450LPH Fuel Pump w/ Rewire
-6AN from hard lines to filter, rail, and regulator
OTHER:
2g power steering reservoir
Mishimoto Catch Cans (-8AN)
1979 Scirocco Style Radiator
12” SPAL Fan (1600 cfm)
Prothane motor mount inserts
Boosted fabrication timing side billet mount
Mods-Engine
2.4L 4G64 (G4CS) 6 Bolt Block
- Wiseco 1400 HD (Coated)
- Eagle H Beam connecting rods
- 2.4L stock crank
- 8.8:1 compression
- Fluidampr harmonic dampener
- All new timing components: pulleys, tensioner, water pump, belt
- Balance shaft delete w/ new oil pump and front case
- Jay Racing Alternator relocate kit w/ Saturn 160 amp alternator.
'91 Galant VR-4 Head
- Kiggly Beehive Springs
- Kiggly HLA Regulator
- 3G 'No Tick' Lifters
- New Guides, Keepers, retainers, etc.
- Supertech black Nitride valves
- HKS 280/280 Cams
- Adjustable cam gears
- Black top CAS
Mods-EMS & Logging
ECMLink v3 Full
Prosport Oil Pressure Gauge
Prosport Water Temp
Innovate LC-2 Wideband
Glowshift 10-Series Boost Gauge
Glowshift A-pillar Pods (2x 52mm)
Mods-Drivetrain
South Bend Kevlar Clutch K05048-SS-TZ
TRE Built 4 Bolt Rear Diff
- 4 bolt rear axles
TRE Built Transfer Case
TRE Built Transmission
- Evo 3 input shaft
- Evo 3 1st gear
- Pre 1990 synchro upgrade
- 4 spider center diff
- glass bead service, gear detail: corner rounding, lead edge trim back, tip relief, engagement teeth profiling, synchro cone modification, modified gearstack offsets, shift rail & selector modification for improved shift quality. high intensity, double saturation, special process, shot peening of gearset and shift rails.
Volk rear upper control arms
3SX 3000GT 4WS Delete Kit
Whiteline 26mm Rear Sway Bar
Bilstein Suspension from Evo 9 MR
Swift Spec-R Springs
Tein Camber Plates
Stock Brakes <Painted Red>
R1 Concepts Rotors:
- SKU(S): 613-72018R,613-72018L,613-72011R,613-72011L
PowerStop pads
ABS Delete Kit w/ stainless front lines + Prop Valve + Stainless brake lines
Boosted Fabrication ECM Tuning ExtremePSI Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com RixRacing RockAuto RTM Racing STM Tuned VR Speed Factory
Dashnizzle
More in 1G DSM
Share this Vehicle
