Please Support Rix Racing
Street Build 1990 Tsi AWD
Ownership Status
Currently Own
Eagle Talon TSi AWD
Turbo Type
HX40
Drivetrain
AWD
Build Type
  1. Street
HX40, 3" turbo back, JMF intake manifold, S90 throttlebody, greddy turbo timer, mishimoto radiator amd fans, 2G TB elbow, SBR FMIC, Tial BOV, Tial dual wastegates, Spark tech COP setup, 91+ PTU, Black top CAS, MAC boost controller, FIC fuel rail, FIC 2150 injectors, aeromotive FPR, SD: boost, A/F, oil temp, coolant temp, Innovate WB.
Mods-Engine
Fresh OEM short block, comp 272 cams, balance shafts deleted, Kiggly HLA, 3G lifters, Kiggly beehive springs and retainers. Engine harness reworked by ESD Custom Wiring to accomodate add ons and deletes.
Mods-EMS & Logging
Dsmlink v3, innovate WB
Mods-Drivetrain
4bolt rear swap, volk rear lower arms, rear subframe cleaned and powder coated, poly bushings all around. Act 2600, streetlite flywheel, braided clutch line.
Tein Coilovers with EDFC controller, poly bushings all around, Megan front and rear strut bars, RM rear sway bar.
Parts Wishlist
upgraded brakes. Torque solutions mounts.
Background
Picked up this vehicle from NJ with as clean of a body as I've seen in years. Plan to do a full paint job first along with replacing a few trim pieces. Will work suspension and drive train first with the few upgrades I listed above and get it tuned. I have another longblock i plan to build over the winter and drop in come spring/summer with a bigger turbo setup. Looking for around 500HP street setup.
Joshua Tadich
More in 1G DSM
Share this Vehicle
