1. Join the Community!
1979 MGB Convertible
Vehicle:
79' MG/MGB
  • Ownership Status:
    Currently Own
    Drivetrain:
    RWD
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    1) Aluminum Cylinder head
    2) Aluminum Polished Valve cover
    3) Factory Hard Top w/ True Safety Glass windows
    4) Dual Pneumatic Bonnet/Hood Shocks
    5) Dual Pneumatic Boot/Trunk shocks
    6) H-4 Headlight Housings
    7) Wood Steering wheel w/ polished aluminum adapter
    Mods-Engine:
    1) Aluminum Cylinder head w/ SS big valves
    2) Eaton positive displacement roots-type supercharger found on contemporary OEM applications. In spite of its modern origin, the system design looks like it was a factory installed option that complements the classic MG image. Intake manifold provides equal airflow, pressure and fuel mixture to each cylinder. By optimizing the distribution in the manifold for each cylinder, you can run more boost pressure without the chance of harmful detonation. System produces 5-6 psi boost at sea level and bolted to a stock engine you can expect a minimum 50% increase in rear wheel horsepower.
    3) SC/Alt./H2O pump Serpentine belt driven
    4) SU 1.75" Side-draft CV carb
    Mods-EMS & Logging:
    1) Petronix Ignition System
    2) Hi-output alternator
    Mods-Drivetrain:
    1) 4-Speed manual w/ Electric shifter controlled 3rd & 4th Overdrive.
    Mods-Handling:
    1) English Mini-lite 6" rims
    2) Drilled/Grooved rotor upgrade
    3) Stainless Steel front brake hoses
    4) Stainless Steel Rear brake hose
    5) Rear Lever shock to Tube shock conversion
Share this Item
Comments
  1. ec17pse
    just seen you own an MGB. if you ever want some tube suspension arms head over to hoyle. I make all the arms and rear subframes for them, im starting to design a front subframe also this year for the MG's
      AMSOIL Dlr #352885 likes this.
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
