- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- 10:1 wiseco with Manley rods acl bearings. Stage 3 head. 282 cams. Borg Warner 258rs. Side exit exhaust. Sbr fmic. Dsm translator. Dsmlink v2.5 hks ssqv. Tial 38mm through hood. Punishment t3 exhaust manifold. Alum rad slim fans. Rear mount battery with shutoff switch. 1000cc injectors. Aem can gears. Old school Dejon intake manifold. Act lightweight flywheel and 2900 clutch. Shep stage 3 trans with welded diff. 1inch lower springs. Ss clutch lines welded pedal assembly. Walbro 450. Adjustable fpr. Only main hoop of cage is welded in needs finished have the parts. Have most of interior minus radio. Made 560 at 34 psi. Mitsu metal head gasket and arp l19 studs. Tuned on q16.Has went a best of 10.5.
- Background
- Only plans are ruling the street and getting into the 9s
