Please Support STM Tuned
You're not fast until....
I was wondering why the bottom of my bumper looked kinda mushed in after the event. Maybe I should try more spring rate in the front.:hmm:
Pregame prep, too many talons, or not enough?
They must be close to stock spring rates LOL i have never seen a cocked wheel on a dsm before, i would worry alot if mine did that
700 and still did that? Your shocks must be shot! Or you have over sprung more then your shocks can handle
Ileagle has some superman brake tecnique. That car doesn't even have ABS. I dont think many others can do that.
I think this is the big full throttle sweeper after the slalom with the tight kink at the end. Looking at the painted lines there is a bump there, I think that contributes more to the tripod than my braking.
That photo must have been one of my slower runs, when I was going in a little to tight. So this is probably more an example of "effort" rather than "skill".
Koni 2812 shocks, my last rebuild was in 2015, based on 2900 lbs and 700-900lb springs.
So is the valving low from maybe the first sring rates and over grown the valving now? Them shocks do t seem like they would do this unless its blown, over sprung for valving or set wayhayyyyyy too soft,
Unless im over looking something here
Turns out this was my fastest clean run. I tagged a cone in the last slalom on a run that was over a second quicker.
This particular event site, specifically this lot (out of the 3 that various clubs race in) gives me a weird side to side pogo motion with this car.
You can see it at 0:50 and 1:05 in the video. The photo was taken at the 1:05 mark.
love the music!!!!!!!!
and i see at 1.05 the front wheels move alot aswell so i can only assume the surface may have been a bit uneven? as a guess anyway from the way the front wheels move around.
Long time overdue response , but yes the shock was blown.
