Archived You should probably just click here - TONS of new parts
Posted by dacowgod, Jun 19, 2017
Please Support Kiggly Racing
  1. dacowgod
    dacowgod Freelancer
    360
    24
    Joined Feb 3, 2006
    Morgantown, West Virginia
    Had a busy weekend - Added a ton removed sold - need something ASK!
    Buschur racing stage 3 head w 1mm oversized valves $700
    Built 6 bolt short block - $2500
    Manley Turbo tuff rods
    Manley 9.2:1 compression pistons
    Eagle crankshaft
    Kiggly girdle
    ARP main studs
    Includes everything from the deck down ready to drop a head on it and go
    Full 1g Auto swap w/ IPT Converter and Kiggly 6 bolt flexplate has 4 bolt rear - $1750
    Complete 2g Auto Swap (Includes everything you need to make a 2g manual AWD an Auto AWD) - $1250
    Complete 1999 Split thrust long block Stock w/ 82K miles on it - $1000
    JMfabrication 1G SMIM - $425
    S90 throttle body -$185
    AEM fuel rail - $100
    Fuel lab AFPR w/gauge, return line and fitting - $130
    1g Walbro 255 - $50
    Sparktech COP -91-94 plug and play unit - $330
    Brian Crower 272 cams - $325
    Brian Crower 288 Cams - $325
    Blue Fidanza cam gears - $130
    HAFE manifold rev3 Cast SS (BEPDSM7) (Has not been drilled for external wastegate but easily done - $225
    FP green turbo with Internal wastegate setup - $700
    Wrinkle Black Valve Cover w -10AN, aluminum baffles, & Gamble Garage catch can - $350
    1g Mishimoto Rad with fans- $200
    Large Auto trans cooler $100
    Forced Four Shift box - $100
    1g Bulfab 3 pc crossmember - $225
    1gAdjustable rear control arms - $100
    Very nice all black leather interior - $500
    Excellent Genuine MHI Evo3 Big 16G Freshly rebuilt by Justin Whitesell (Setup for External Wastegate) - $500
    Injen intake - $75
    Brand new Tial MVS 38mm (Polished) Has been mounted but never ran - $225
    Used Tial MVS (38mm VBand) Black - $200
    New Punishment racing intercooler kit(Mounted but never ran) - $300
    Brand new JMFab 38mm VBand O2 housing w/ open dump tube (Mounted but never ran) - $325
    Brand New OEM MHI Evo3 exhaust manifold(part number MR224509) (Mounted but never ran) - $150
    Black Hallman Manual Boost Controller - $50
    6 Bolt ARP Head studs - $50
    7 bolt ARP Head studs - $65
    2g ECMLink SD harness - $50
    FP Exhaust manifold - $200
    SS o2 housing with Tial F35 gate and open dump tube - $225
    Bullseye S256 in DSM Bolt on housing - $625
    BLE Solid timing belt tensioner(6 bolt) - $90
    Fuel Lab Prodigy in line Fuel pump - $325
    Complete Holset h1c Setup - Made 412 AWHP with this configuration includes turbo, T3 manifold(Has a small crack) and vband downpipe/clamp, xspower 38mm wastegate - $500
    Brand new DNP Style(No name though) DSM Flanged tubular exhaust manifold - $65
    Used DNP Style(No name) DSM Flanged tubular exhaust manifold - $50
    JPipe - $25
    holset H1c parts turbo has some turbine damage, turbo came loose from its housing- $50
    Custom Billet 67mm Hx40- This turbo went 8.7's on Dave Ruby's Race car. 67mm Compressor Large 10 blade turbine open T3 exhaust .82 AR - $825
    Red Holley Fuel Rail - $75
    Brand new in box Precision 6266 Gen 2 DBB in .82 T3 hotside - $1575
    EVO 3 O2 housing - $75
    Built 6 bolt short block- $1600
    good 6 bolt shortblock - Has some vertical scratches in the bores nothing terrible engine had 165-170 compression across the board and did not smoke or carry on - $550
    Garrett GT35R Dual Ball Bearing T3 4bolt out - $850
    Brand new 2g/EVO Oliver Billet Ultralight rods - $750
    2g black box ECU - $85
    Billet Aluminum crank pulley - $40
    Used MHI 13g turbo - $75
    Used MHI 14b turbo - $110
    Used T25 turbo - $115
    Good used Gates Racing Kevlar Timing belt (Blue) - $50
    Purple Fuel lab Fuel Filter -8an - $85
    Weldon Inline fuel filter -6an $85
    Genuine Greddy Type S Blow off valve w/ push to connect airline fitting - $75
    Genuine Greddy Type S Blow off valve - $85
    Genuine Greddy Type RS Blow off valve - $90
    Good stock 95-96 2g AWD 5 speed transmission 140K miles- $500
    97-99 2g AWD 5 speed trans (pops out of first) good core unit- $350
    Brand new in box 6 bolt ARP main studs - $60
    Good used ARP 6 bolt head studs - $50
    ACT 2600 pressure plate - $125
    ACT 2100 Pressure plate - $125
    good used ACT 2600 clutch - $225
    2g ECMLink GM MAF Harness $65
    Evo 8 K&W typhoon intake system $50
    2g Tokiko Blues w/ Tokiko Red springs (low mileage) - $325
    Act Streetlite 7bolt fwd flywheel - $100
    Braille - Small battery tie down/tray - $85
    Good 2g MAF - $25
    2g Lamborghini style bolt on door hinge assemblies - $250
    os giken DSM twin disc clutch - worked well but will need a rebuild - $450
    Revised 3g Lifters - $65
    Holset HX40/35 hybrid w/ 12cm T3 Housing (Rebuilt by Justin Whitesell 2000 miles ago) - $475
    2g LSD Manual rear diff - $225
    2g pair LSD rear axles $200
    2g LSD Auto Rear end - $225
    2g Non LSD Auto Rear end - $200
    2g 91-96 Auto Tcase - $175
    22 spline manual tcase - $150
    23 spline manual tcase - $175
    97-99 manual tcase 23 spine - $175
    Good manual half shafts w/ carrier - $75
    Cleaned and flowtested Stock 450 DSM injectors(Blue tops and black tops) - $75 per set
    Cleaned and Flowtested Rc 550 injectors - $100
    Cleaned and Flowtested FIC 850cc injectors - $225
    1g AWD Fuel Sending Unit - $100
    2g AWD Fuel Sending unit - $100
    2g non abs prop valve w/ hard lines - $80
    1g non abs prop valve with hard lines - $80
    2g complete core head (Running pull) $225
    1g Complete core head (Running pull) $225
    Recently rebuilt to stock 1g head - $300
    Good 2g short block 95-96 Running pull $550
    Good Engine harnesses (1g/2g Auto and 5 speed available) - $175
    1997 Eclipse GST - R Titled(Car is straight though) - California car absolutely no rust but has clearcoat issues - $2500
    Soon to be for sale -
    1995 Talon TSI AWD 5 speed(This car is being reassembled as i post) - $3500
    1995 Talon TSI AWD 5 speed(This car is next in line for reassembly after the above)- $3500
    Located in Morgantown WV - - MUCH more not listed PLEASE CALL OR TXT
    304-813-2405
    Log in/Register to remove ads
    My DSM:
    1997 Mitsubishi Eclipse GSX
    10.920 @ 133.900 MPH
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory White Shed Speed
