1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
2G Xona Rotor Turbochargers
Posted by TSiBOLO, Nov 12, 2018
Please Support Morrison Fabrications
  1. TSiBOLO
    TSiBOLO Proven Member
    52
    5
    Joined Aug 6, 2016
    Milford, Michigan
    Is anyone running these beauties on their 2.0s? Was wanting to run a 6266/6466 comparable version for my 9:1 build this winter.
    Log in/Register to remove ads
    My DSM:
    1995 Eagle Talon TSi AWD
    Street Build
    50trim   automatic
    Loading...
    Featured Products from our Supporting Vendors
  2. JusMX141
    JusMX141 Moderator
    12,731
    713
    Joined Dec 13, 2005
    Greensburg, Pennsylvania
    Which one, specifically? Most of them are just renamed versions of FP turbochargers that have been available for a few years.
    Loading...
  3. TSiBOLO
    52
    5
    Joined Aug 6, 2016
    Milford, Michigan
    The XR8267 in particular.
    My DSM:
    Street Build
    50trim   automatic
    Loading...
  4. Vegas smith
    Vegas smith Proven Member
    2,197
    954
    Joined Dec 2, 2002
    Houston, Texas
    I think Scott Laird runs. Hit him up on Facebook. I forget his name on here.
    My DSM:
    1993 Eagle Talon TSi AWD
    Street Build
    GT30   manual
    1992 Eagle Talon TSi AWD (sold)
    16g   manual
    Loading...
  5. TSiBOLO
    52
    5
    Joined Aug 6, 2016
    Milford, Michigan
    I don’t have Facebook unfortunately, but thank you!
    My DSM:
    Street Build
    50trim   automatic
    Loading...
  6. TSiBOLO
    52
    5
    Joined Aug 6, 2016
    Milford, Michigan
    I ended up buying the 95•67 from ArcherFab during his Blackfriday sales. Was curious to know if I would be misusing this turbo on a 9:1-9:5 compression engine. I’m only on 93 currently.
    My DSM:
    Street Build
    50trim   automatic
    Loading...
    Archer Fabrications likes this.
  7. ec17pse
    ec17pse Freelancer
    3,003
    984
    Joined Nov 1, 2008
    London, Europe
    I read the xona turbos are Tial branded or made by Tial, maybe my googling failed me but thats what i took from reading online, so they have a nicer CHRA setup but if its based on a FP turbo is there still going to be the same lower quality we see and reliability from the FP name?
    My DSM:
    1997 Mitsubishi Eclipse GST
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  8. JusMX141
    JusMX141 Moderator
    12,731
    713
    Joined Dec 13, 2005
    You bought a FP Super 94. Look around, there should be plenty of info on users running that turbo...although you'll definitely want a different fuel than pump gas if you want the turbo to work well for you.
    Loading...
    TSiBOLO likes this.
  9. TSiBOLO
    52
    5
    Joined Aug 6, 2016
    Milford, Michigan
    I haven’t been around long enough to know about FP’s wrongdoings or poor quality but from what I’ve experienced and read they seem to be a great company. But more so what I was referring to was possibly running lower compression and higher boost...
    My DSM:
    Street Build
    50trim   automatic
    Loading...
  10. TSiBOLO
    52
    5
    Joined Aug 6, 2016
    Milford, Michigan
    Would water/meth be exceptable? E85 is a 20min drive from me. Also thank you for the Super 94 cross reference. I’ll do some reading up.
    My DSM:
    Street Build
    50trim   automatic
    Loading...
  11. JusMX141
    JusMX141 Moderator
    12,731
    713
    Joined Dec 13, 2005
    I can't think of anyone personally running pump gas on a 700+whp 4G63 build. Realistically that turbo is rated for something like 90 lb/min so that's closer to 900 at the crank. Pump gas effective limit seems to be around 500-550 horsepower on our platform depending on the turbo selection. You can make more but at some point the graph between power made and power you're leaving on the table takes a sharp turn upward.
    Lower octane fuels burn quicker; often the fuel will start burning under compression alone before the compression cycle reaches top dead center which can start a downward spiral of knock. A methanol-laden air charge can cool the combustion cycle down enough to aid in knock prevention but it doesn't always alter the point in the cycle at which the fuel itself burns under compression. Trying to tune around detonation forces the timing "punch" out of the tune at peak torque and makes the turbo feel lazy as a result. If you're drag-only where the RPMs are constantly above peak torque it doesn't really matter, but for street driving you lose that "wow" factor for your passengers where you can just mash the throttle and let them see sky when the turbo lights.
    At high RPM with a forced-induction application you're leaving a lot of power and potential on the table by staying with a poor quality fuel. I'd find an empty drum and fill it up if you have to. It seems counter-productive to install a $2000 67mm turbo on your car only to be held back by fuel type.
    Loading...
    TSiBOLO and MorrisonFab like this.
  12. Vegas smith
    2,197
    954
    Joined Dec 2, 2002
    Houston, Texas
    You should have asked this question before you bought the turbo :)
    My DSM:
    Street Build
    GT30   manual
    16g   manual
    Loading...
  13. Boomdeeze
    Boomdeeze Proven Member
    1,494
    193
    Joined Jul 5, 2009
    Independence, Minnesota
    Did I miss a thread on FP not having good quality turbos? I've been running the HTA76 (Xona Rotor DSM 61-56) since 2015 at ~40 psi without one issue. I'm not saying no one has had an issue with a single turbo but wondering where this came about.
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
    10.793 @ 128.98 MPH
    Loading...
    TSiBOLO likes this.
  14. TSiBOLO
    52
    5
    Joined Aug 6, 2016
    Milford, Michigan
    Thank you for all the knowledge JusMX. I will switch to e85 then. I bought this turbo because in my mind it would be the last I’d ever need. Doubtfully I will ever max it out. Likewise with the motor build, Manley crank, Manley turbo tuff I-beams and wiseco 1400hds, 625+ head studs, arp main studs and so on.
    And you’re probably right but I thought I could get some opinions now. I had it in my mind that being auto the 9.5:1 would be great to get me through the low rpms faster. But wouldn’t be able to run much boost.
    My DSM:
    Street Build
    50trim   automatic
    Loading...
  15. Vegas smith
    2,197
    954
    Joined Dec 2, 2002
    Houston, Texas
    Some folks are skeptical of FPs quality on their journal bearing line.
    My DSM:
    Street Build
    GT30   manual
    16g   manual
    Loading...
  16. 1cleangsx
    1cleangsx Proven Member
    41
    14
    Joined Sep 28, 2013
    Cheyenne, Wyoming
    I’ve been running my jb red at 30+ psi since May, actually 35psi for a couple months now and still has zero shaft play, I know people say to not go over 30 if you want them to live but I don’t drive my car an excessive amount, and I wasn’t seeing the airflow I wanted until I went over 30psi, so far the red has continued to pump out more airflow the more I’ve turned it up, but I’ll probably stop at 35 psi and report back in a year LOL
    My DSM:
    1990 Mitsubishi Eclipse GSX
    Street Build
    13.2 @ 104.64 MPH
    Loading...
  17. ec17pse
    ec17pse Freelancer
    3,003
    984
    Joined Nov 1, 2008
    London, Europe
    Its a hit and miss thing. Some folks have zero issues and other people have major problems from stsrt to finish and end up going a different brand turbo because of the issues, i read good snd bad things but over the last few years i tend to see more negatives then good. Maybe because people post more abiut bad vs good nowadays i dont know plus if memory is well justin said once abiut the amount of rebuikds he had from FP turbos even being used correctly was quite high,
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  18. donniekak
    donniekak DSM Wiseman
    4,510
    755
    Joined Mar 23, 2008
    Surprise, Arizona
    You’re going to need a good converter and nitrous to launch with that turbo.
    My DSM:
    1991 Eagle Talon TSi AWD
    Street Build
      manual
    Loading...
    TSiBOLO and OH91awd like this.
  19. TSiBOLO
    52
    5
    Joined Aug 6, 2016
    Milford, Michigan
    Definitely, but I want to get motor squared away right now.
    My DSM:
    Street Build
    50trim   automatic
    Loading...
  20. Archer Fabrications
    Archer Fabrications Supporting Vendor
    6,093
    838
    Joined May 9, 2011
    Scottsdale, Arizona
    For those that dont know, Xona is the joint venture company between FP, TiAL and owen development. The MFG happens at tial, and uses FP aero. Xona uses billet stainless Ballbearing center cartrages, journal bearing isnt an option. They also just released a new ULTRA HIGH FLOW turbine design this week that they are saying is a game changer.
    Ian, hope you enjoy your turbo and make good power with it! Your top mount manifold is going to be assembled soon!
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Drag Race Build
    11.128 @ 132.5 MPH
    Loading...
    TSiBOLO likes this.
  21. TSiBOLO
    52
    5
    Joined Aug 6, 2016
    Milford, Michigan
    Thanks brother, can’t wait to hit the streets. Also just saw that new UHF turbine wheel on their Instagram. Thinking quicker spoolup?
    My DSM:
    Street Build
    50trim   automatic
    Loading...
  22. Archer Fabrications
    6,093
    838
    Joined May 9, 2011
    Scottsdale, Arizona
    We shall see with testing, but I assume it’s aimed at ultra high flow LOL
    Also, the 95•67 is not like the super94, it has the smaller gt37 turbine like the hta3794 @JusMX141 the 95•68 is the super94’s replacement.
    My DSM:
    Drag Race Build
    11.128 @ 132.5 MPH
    Loading...
    DGajre777 likes this.
  23. ec17pse
    ec17pse Freelancer
    3,003
    984
    Joined Nov 1, 2008
    London, Europe
    So this is not built in fp workshop? But at tial, is that what im reading correctly
    My DSM:
    Road Race Build
    175 whp   180.1 lb/ft
    Loading...
  24. JusMX141
    JusMX141 Moderator
    12,731
    713
    Joined Dec 13, 2005
    They basically copied the compressor design and reverse-engineered it to the turbine. It's like clipping half of the blades instead of all of them...I'm in for results but I don't anticipate anything substantial in the flow department as I've been screwing with clipping and lesser-blade-count turbines for years with varying results. At the end of the day a 62mm (or whatever size) hole is going to flow what a 62mm hole will allow.
    Whatever. They both use the same compressor anyway- and Super 94 had a 67mm turbine exducer, not a 68mm...unless FP is inventing new names for wheels that already exist again like they did the 71HTA. Seems like they rename the lineup or reinvent the wheel so-to-speak every couple years to add confusion and keep selling products.
    Loading...
  25. Archer Fabrications
    6,093
    838
    Joined May 9, 2011
    Scottsdale, Arizona
    I believe some are assembled at fp but the actual Machining and development is at tial as far as I know
    if you read on that seemed to have been human error on website discription on michaels part. Also I remember when the super94 came out they discribed it as “it’s like the 3794 went to the gym packing a new big punch” because they changed the turbine size. I remember because I was looking at these turbos myself, and the fact the 67mm turbine would spool slightly quicker then a 68 is what turned me to it over the larger. But we are only talkin 1mm here
    My DSM:
    Drag Race Build
    11.128 @ 132.5 MPH
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
