Stapl3
- 1,828
- 399
- Oct 27, 2004
MI,
Michigan
I've been spending fall and winter rebuilding the engine in my 92tsi. I just got it back together and it won't hold idle. Basically it starts, revs up to 2500-3000, then just dies about 2-3 seconds in.
6 bolt 2.0 8.5:1
hks 272s
evo 560cc injectors
93oct @ 37psi
virgin 2g maf
stock tb/manifold
new bosch o2 sensor
isc is good
tb and throttle closed switch is adjusted perfectly
I've played with 180'ing the cas and swapping the plug wires. I've also played with the BISS. It's 2 full turns out right now, but nothing changes when I mess with it either way.
Thanks for any help.
6 bolt 2.0 8.5:1
hks 272s
evo 560cc injectors
93oct @ 37psi
virgin 2g maf
stock tb/manifold
new bosch o2 sensor
isc is good
