TheFallenTSI97
- 80
- 0
- Mar 23, 2013
Huntsville,
Alabama
I've decided that the pistons in my 6 bolt aren't quite up to spec. Also one of my buddies had the pry bar slip while removing the cylinder head and now I have a good size gash in the top of one..... But anywho, I'm debating on if the Wiseco standard pistons will be enough. I have a Precision Engineering PT6262, methanol injection, and possibly a small shot of Nitrous for passes at the strip. I was thinking I should pony up the extra money for the HD pistons and have that extra security. But this is something I want to be able to drive around on the streets on low PSI and pump gas. So my next question is, if I did go with the HD pistons would they still be street-able? Thanks in advance for any insight.
