lccynmbr13
- 232
- 0
- Sep 10, 2006
Renton,
Washington
Motors burning a quart every 150mi now time to rebuild. I'm going with 8.8:1 Wisecos again but I'd like to hear some input on piston to wall clearance and ring gap. I previously made 514hp/484 tq on my current setup with what I believe was a .004 PTW and I have no way of finding out what the ring gaps were since I didn't build the motor. I'll be building this one and I have some specs of my own in mind. I don't plan on ever running nitrous but I will occasionally be hitting around 40psi boost pressures at the track and consistently high 20s on the street with water/meth on an FPT04Z88HTA (damn that takes too long to type). I really want to go less than .004 on the PTW as I'm tired of the constant oil burn. If I run a .0035 PTW with 0.19 top ring and 0.21 bottom ring will that be sufficient clearance for a 650-700hp build?
