gunnermaiden
- 72
- 1
- Jul 27, 2016
Phoenix Area,
Arizona
Hey guys, long time no post!
I did search before posting but it seems like everyone's electric problems are pretty dang specific, couldn't find anything that answers my question.
So I went out to cruise in my car yesterday and finally it didn't start for the first since I owned it (bought it last year).
It's always been a pretty hard starter, but usually if I depressed the gas pedal just a bit it would be enough to get it going. The last time I drove it, it stalled out at a light but kicked over right away when I turned the key then was fine. (After I just typed this and thought about I should probably make sure there's no fuel clogs too..)
I had it parked in a cool garage for about 2 months after that. (I attached a photo), I found really bad corrosion (which is new) on the positive battery post, traced the wire to where it was grounded and it looked pretty bad on both ends. Obviously I'm going to have to replace it as it's pretty fried.
Now my questions:
1) I'm looking for a battery cable, none of the new ones I'm finding are labeled positive or negative, does this matter or does it only matter how they're mounted/grounded?
2) As I mentioned my car was always a hard starter, could it really have been just that one cable all along or are there other things I should examine electrically too? (The car does click when trying to start, but I can't tell where it's coming from).
3) This car has a million things wrong with it electrically, what are some other symptoms that bad battery cables could cause? I checked the negative wire and it seems to be in good condition and it is properly grounded. I'm hoping I'll kill 2 birds with one stone by replacing the one cable
I should note that the second pic is how the previous owner rigged up the power to the HID kit they installed (thin red wire). I'm suspecting that had something to do with how the cable got fried in the first place as that does not look appropriate to me at all. I disconnected the kit as of yesterday and am planning on redoing it a better way.
Now my questions:
