ilco187
- 1,707
- 7
- Jan 3, 2009
Niles,
Michigan
heres my wire tuck, i mean suck, looks like trash so im still working to eliminate all unused wires all the way back to the ecu.
Note: This feature currently requires accessing the site using the built-in Safari browser.
My fuse block, is mounted underneath my intake pipe, I used the original bracket moved and twisted a wee' bit and a ziptie, out of sight, out of mind good luck with yours! At least your engine is out? Haha.
I placed the fuse block under the intake pipe. You can see it if you look reaaaaal close.
And matt, is there even a harness in your car? Nothing is plugged in.
Your Engine Bay looks absolutely amazing. Probably one of the best 2Gs I have seen.mattsGSTeclipse
Could you take some closer pictures to show how you routed the wires? Looks good!
Here's my wire tuck. Fuse box where the hvac crap was under the dash. I'll try to get a picture of what it looks like now. I have a new valve cover, installed my jmfabs heat shield and I put my strut tower bar back on.
NO you should be good no worry's.
