Please Support STM Tuned
Please Support ExtremePSI
2G Window rattle (Solved)
MasterMatt209
473
30
Jan 17, 2015
Danville, Indiana
The gold piece shown in the picture seems a little loose and causing my window rattle problem, it’s not horrible but I’d like it to be solid. There’s only one nut on top that I tightened but still seems loose on the bottom, any help? Where you see the white plastic in the picture that is on the gold piece, that is what has play.
Here’s the picture sorry, this so for my Talon she’s perfect. Getting around to the Eclipse later today. Also figured out I could take this piece out and clamp it so it was tight. So much better the door doesn’t sound like my glass is about to break anymore haha. Hopefully this helps someone. Just take off the 10mm bolt and slid the piece off. Put it in a vice and make the plastic pieces closer together.
Damn Imma pop mine open in bit to check this out
Do it, also tighten the regulator nols if you need to like tk106 said. Also before finding that problem one of the bolts that holds the window to the up and down arm things came off I felt around the bottom of the door and found the hardware and put it back on. So much better now!
