1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
2G Will this coolant bottle work?
Posted by PlanZero, Aug 11, 2018
Please Support Boostin Performance
  1. PlanZero
    PlanZero Proven Member
    1,354
    248
    Joined Aug 13, 2013
    Easton, Pennsylvania
    This $20 ebay bottle has one port at the bottom. If I connect the hose from the tstat housing to this will it still function properly? Not sure if gravity plays a role in the normal operation of the reservoir.
    Log in/Register to remove ads
    My DSM:
    1996 Mitsubishi Eclipse Spyder GST (sold)
    Street Build
    T25   automatic
    1996 Eagle Talon TSi
    Street Build
    16g   automatic
    1997 Eagle Talon TSi AWD
    Street Build
    T25   automatic
    Loading...
    Featured Products from our Supporting Vendors
  2. tametalon92
    tametalon92 Proven Member
    1,442
    281
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Technically yes it would. usually you'll want them vented at the top so it's not working against a pressurized or vacuumed system. Could add a vented cap or a breather with baffle if you wanted.
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
      manual
    Street Build
    14b   manual
    Loading...
    PlanZero likes this.
  3. PlanZero
    1,354
    248
    Joined Aug 13, 2013
    I suppose i could drill a hole and put a hose there or possibly one if those goofy little filters just to keep it breathing
    My DSM:
    Street Build
    T25   automatic
    Street Build
    16g   automatic
    Street Build
    T25   automatic
    Loading...
  4. 007jimmy
    007jimmy Proven Member
    1,432
    62
    Joined Feb 27, 2012
    Levittown, Pennsylvania
    As I replied in your catch can thread, I have this bottle as well.... you will need a vent but it works fine. I just put a small hole near the top with a hose barb. I made the mistake of not venting it and I got coolant seepage coming from the water neck. After drilling the seepage stopped. Lesson learned....
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
      automatic
    Loading...
  5. PlanZero
    1,354
    248
    Joined Aug 13, 2013
    007Jimmy, where are you mounting yours?
    My DSM:
    Street Build
    T25   automatic
    Street Build
    16g   automatic
    Street Build
    T25   automatic
    Loading...
  6. jakk220
    jakk220 Proven Member
    1,061
    169
    Joined Nov 13, 2010
    Akron, Ohio
    My DSM:
    1997 Eagle Talon N/T (sold)
    Autocross Build
      manual
    1993 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
