Will K&N FIPK fit an Injen intake pipe?
Posted by kmoore, Mar 29, 2006
Please Support Kiggly Racing
  1. kmoore
    kmoore Proven Member
    999
    4
    Joined Mar 8, 2006
    St, Louis, Missouri
    Hey guys, i am looking at the Injen intake kit for my 97 GST. Will my K&N air filter (pictured below) fit on the Injen intake pipe? I have heard two things, one that the k&n filter WILL fit and another that the k&n air filter WILL NOT fit. I want to save a little money if i could by keeping my filter on the injen intake that i already have rather than buying and new filter that comes with the kit. Thanks!:dsm:
    Log in/Register to remove ads
    My DSM:
    Loading...
  2. clipse0001
    clipse0001 Proven Member
    198
    3
    Joined Jul 26, 2005
    blacksburg, Virginia
    yes it will
  3. MyBeatGSX
    MyBeatGSX Proven Member
    1,218
    26
    Joined Jul 17, 2005
    Southington, Connecticut
    What he said.
    The K&N filter stays on the MAF, the MAF attaches to the intake pipe where the stock one does.
  4. kmoore
    999
    4
    Joined Mar 8, 2006
    St, Louis, Missouri
    Yeah i know the filter stays on the MAF but will the injen intake be too long and have the filter hit the inside fender and intercooler pipe? Thanks for the quick response also
    My DSM:
    Loading...
  5. MyBeatGSX
    1,218
    26
    Joined Jul 17, 2005
    Oh my bad, I shouldn't assume people are that dumb LOL.:nono: Sorry.
    It should fit. I have the extremepsi. intake pipe and BARELY clears the fender. I've seen the injen one with a K&N on a 2G before and looked like it fit better than mine.
  6. clipse0001
    198
    3
    Joined Jul 26, 2005
    you should replace that bov too. and you have pm.
    Anton
  7. redmayns
    redmayns Proven Member
    55
    Joined May 19, 2004
    West Sacramento, California
    hey, you are going to have a little trouble cause i think the filter will touch a tinny bit, nothing too big, it took me a little brain power OMG to fit it in with my greddy pipng, hey if you need a rfl bov or a blitz dd bov, pm me or mail me at redmayns123@yahoo.com i have both and i wanna get rid of them for like 50 bucks a piece, or else just get back to me and we can work something out.
  8. daren_p
    daren_p DSM Wiseman
    4,548
    81
    Joined Nov 22, 2004
    Newmarket, ON, Canada
    Yes it can be made to fit, but like has been said the Injen intake places the MAF closer to the passenger fender so it will be a tight fit. I do know a couple people that have this setup and they got it to work.
    My DSM:
    1998 Mitsubishi Eclipse GSX
    12.370 @ 119.800 MPH
    Loading...
  9. kmoore
    999
    4
    Joined Mar 8, 2006
    St, Louis, Missouri
    daren p what do you mean when you say "It can be MADE to fit?" I am a little confused when you say that. Do you mean i will have to cut an inch or so off the pipe? Thanks for the replies
    My DSM:
    Loading...
  10. Nonrml4
    Nonrml4 Proven Member
    127
    3
    Joined Dec 11, 2005
    Toledo, Ohio
    I dont think you have to cut it, I have a buddy that runs a similar setup (ebay metal intake w/ k&N fipk) and he just had to persuade it a little bit. John
  11. 1glaserturbo
    1glaserturbo Proven Member
    302
    Joined Feb 12, 2005
    Creve Coeur, Missouri
    That intake will fit, my buddy in his GS-T is running the same exact one. Filter and all!
    My DSM:
    Loading...
  12. clipse0001
    198
    3
    Joined Jul 26, 2005
    why would you tell someone to vent to the atmosphere?
    just wondering
    Anton
  13. kmoore
    999
    4
    Joined Mar 8, 2006
    St, Louis, Missouri
    So you guys are saying that i shouldn't have a problem fitting the filter on the Injen intake and that i won't have any clearance issues? Will ANYTHING at all be hitting or making a noise if i install this thing? Thanks
    My DSM:
    Loading...
  14. jtxtrmboost
    jtxtrmboost Probationary Member
    24
    Joined Mar 25, 2004
    Grand Rapids, Michigan
    From past experience on my old set up the K&N FIP fits "barely" with the Injen intake pipe. (It hugs the passenger inner fender wall). You have to give it a little extra "push" but it works, my advice would be to take the filter itself off the MAF and install everything - then put the filter on last - that way you can slip the filter over the MAF on an angle. If you get the hard upper intercooler pipe it gets even more snug at the inner fender wall, but it can be done. Works great though:thumb:
    Oh - definitely need a new BOV - soon!
    Good luck, the exact set up got me into the low 14's alone!
  15. Zmann42087
    Zmann42087 Proven Member
    570
    18
    Joined May 9, 2005
    Champaign, Illinois
    You are going to receive replies saying it does fit and doesn't fit. Bottom line is it can be made to fit, but it will be a tight squeeze.
    No, definitely don't trim the pipe. I emailed a guy on here a while back about making the K&N FIPK fit with an Injen pipe. Unfortunately, I can't remember his name, but my point is he DID successfully install both. How??? He built a custom bracket to hold the air filter down. This did the trick, as the air filter now clears the fender well.
    Here are some of the pictures he graciously sent me...
    [​IMG]
    [​IMG]
    I hope this helps you out. If you have any more questions let me know.
    -Andrew
    My DSM:
    Loading...
  16. davidalindsey
    davidalindsey Proven Member
    305
    3
    Joined Nov 5, 2008
    Norfolk, Virginia
    I know old thread....
    I just installed a K&N FIPK with my Injen intake.
    Fits perfect, I just didnt use the mounting hardware.
    Loading...
  17. LiquidX
    LiquidX DSM Wiseman
    6,594
    92
    Joined Sep 19, 2008
    Anywhere, Pennsylvania
    My DSM:
    1997 Eagle Talon TSi AWD
    Street Build
      manual
    Loading...
  18. Alan11
    Alan11 Proven Member
    614
    Joined Apr 30, 2010
    El Paso, Texas
    Loading...
  19. 907gs-t
    907gs-t Proven Member
    741
    5
    Joined Feb 3, 2009
    Juneau, Alaska
    Same thing I've been running for a couple of year's now with no issuse's.
    My DSM:
    1998 Mitsubishi Eclipse GST
    11.899 @ 126.000 MPH
    Loading...
  20. Boostinsideways
    Boostinsideways Banned Member
    1,125
    7
    Joined Feb 4, 2011
    Arab, Alabama
    In any case, you can allways either open up the the fender wall, or shorten the pipe.
    Loading...
  21. davidalindsey
    305
    3
    Joined Nov 5, 2008
    Norfolk, Virginia
    No way would I cut into a $250.00 intake.
    Loading...
  22. Tyeler18
    Tyeler18 Proven Member
    1,988
    43
    Joined Dec 16, 2008
    Casa Grande, Arizona
    No way would I BUY a $250 intake pipe. ROFL
    My DSM:
    1990 Eagle Talon TSi AWD
    Road Race Build
    GT30   manual
    Autocross Build
    16g   manual
    1991 Mitsubishi Galant VR-4
    Road Race Build
    GT35   manual
    Loading...
  23. idkiliketurbos
    idkiliketurbos Proven Member
    536
    48
    Joined Mar 2, 2009
    Fox Valley, Wisconsin
    Don't the dejon intake pipes work with the K&N FIPK kit well? I would definatly look into that before paying big bucks on something that will be a very tight squeeze.
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
    GT30   manual
    Loading...
  24. davidalindsey
    305
    3
    Joined Nov 5, 2008
    Norfolk, Virginia
    I agree, thats why i didnt buy it.
    It was already on the car when i got it. :p
    Loading...
  25. 4Lurker4
    4Lurker4 Proven Member
    1,114
    18
    Joined Jan 11, 2009
    Brampton, ON, Canada
    Yuppers, and they fit perfect; had one before.
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
