AWD-Tony
- 6,801
- 3,735
- Sep 11, 2017
Cincinnati,
Ohio
I can't get my ISC set to 30 and I've tried everything so I plan on leaving it as is. Will this cause an issue with WOT and/or cruse tuning?
Note: This feature currently requires accessing the site using the built-in Safari browser.
I've talked to multiple tuners that will do WOT tuning first because they'll use Global fuel adjustments, then move onto cruise and idle. The reason being if you tune idle and cruise perfectly, then do your WOT tuning, you may change your global fuel and then have to redo everythuingI don't claim to be a tuning expert but I wouldn't even consider going WOT until I had the cruise tuning dialed in.
