why would i have to pump my gas to get my car to start?
Posted by 97-gst, Jun 29, 2010
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support VR Speed Factory
  1. 97-gst
    97-gst Proven Member
    DSM Profiles:
    May 16, 2010
    769
    Radford, Virginia
    does anyone know why i have to pump my gas while starting my car?
    #1
  2. housegsx
    housegsx Moderator
    May 28, 2004
    1,260
    21
    Greensburg, Pennsylvania
    Because your carb is gunked up...
    Nah, maybe a bad isc motor or something. Do you need to do that all the time? Just when the engine is hot/cold?
    #2
  3. DSMopar
    DSMopar Proven Member
    Oct 6, 2007
    526
    3
    Vista, California
    Exactly what I was going to say :D
    #3
  4. 97-gst
    DSM Profiles:
    May 16, 2010
    769
    Radford, Virginia
    Its got a new 1000 dominator carb on there, it cant be that.
    But really, i have to pump the gas everytime, no matter if its hot or cold, It doesnt matter to me it starts good once i pump the gas. Is this bad on anything?
    #4
  5. crash89
    crash89 Supporting Member
    DSM Profiles:
    Mar 5, 2008
    1,928
    71
    Janesville, Wisconsin
    It could be possible that your stock FPR is going bad which is causing your fuel system to no hold sufficient pressure in the fuel rail.
    #5
  6. beating4g63s
    beating4g63s Proven Member
    Oct 31, 2004
    331
    port arthur, Texas
    beat me to it.
    #6
  7. EclipticalGS
    EclipticalGS Proven Member
    Aug 25, 2008
    1,133
    11
    walker, Michigan
    The auto starter fluid canister has to be filled, its underneath the rear seat.
    Isc, fpr, fuel filter, boost leak, o2 sensor dumping gas.
    #7
  8. tsi1991awd
    tsi1991awd Proven Member
    DSM Profiles:
    Sep 28, 2008
    1,309
    4
    Puyallup, Washington
    Wowwww....I am shocked at the answers everyone is giving.
    You pumping the pedal is an illusion...it is the excessive cranking that you are doing that is allowing the car to start.
    Pumping the pedal will do nothing on an EFI motor. Pumping the pedal on a carbuerted vehicle works because it will allow gas to be injected directly into the carburetor where the magic happens.
    All you are doing is opening and closing the butterfly on the throttle body allowing more/less air to enter the engine while cranking.
    Your problem may lie in the fuel system...check the check valve by the fuel pump cover. Check the O-ring on the fuel pump output shaft inside the tank.
    Can't believe anyone hasnt said this....CHECK YOUR CTS. That may be the only cause. Bad CTS's are notorious on DSMs and they make your car very very hard to start.
    #8
  9. SlushBoXRacer
    SlushBoXRacer Proven Member
    DSM Profiles:
    Oct 13, 2005
    37
    Corona, California
    i would say it could be a fuel issue FPR or pump. . but pumping the gas on a fuel injected engine? fail.
    #9
  10. housegsx
    housegsx Moderator
    May 28, 2004
    1,260
    21
    If it is the ISC then pumping the pedal would do something. If it is not opening at all, cracking the throttle plate will allow air in.
    OP, does it eventually start if you just crank it long enough without pressing the pedal? I don't know about the FPR leak being an issue either, as mine doesn't hold pressure long, but always starts right up.
    #10
  11. 9!'clipseDOHC
    9!'clipseDOHC Moderator
    DSM Profiles:
    Aug 24, 2003
    3,448
    153
    El Paso, Texas
    What is a CTS? I'm having a similar problem. I have a rewired Walbro 255 and a Bushur/SX AFPR, the rest of the fuel system is stock. I have had both for the last 5 years with ZERO problems. I changed the turbo 2 weeks ago and arced the alternator, ever since then its been hard to start. I instantly have ZERO fuel pressure after shutdown. I started a thread about it but no love.
    #11
  12. tsi1991awd
    DSM Profiles:
    Sep 28, 2008
    1,309
    4
    The CTS is the Coolant Temp Sensor. It sends the temp of the motor to the ECU so that the ECU knows how much gas to pass through the injectors to start the motor for the given temperature.
    When these fail (which happened on my other DSM), they will read open continuity and will be hard to start. These have a certain resistance, something like 2000ohms at 70* or something like that. If the resistance isn't right, the ECU will allow for less than sufficient fuel injection at startup.
    I would check the resistance between the two prongs on the CTS (located on the thermostat housing) to see what it reads. Keep checking it as it warms up....as it warms up, the reading should get lower. If nothing changes then it's shot.
    #12
  13. ChillinGST
    ChillinGST Proven Member
    DSM Profiles:
    Sep 13, 2008
    117
    Clearwater, Florida
    Throttle Position Sensor was first thing that came to mind. I'd check it out with a multi-meter.
    #13
  14. 9!'clipseDOHC
    DSM Profiles:
    Aug 24, 2003
    3,448
    153
    El Paso, Texas
    Oh ok. I've been thinking that its electrical since it first started after I arced the alternator. Is there a relay or fuse for the CTS that might have blown?
    #14
  15. tsi1991awd
    DSM Profiles:
    Sep 28, 2008
    1,309
    4
    No, the ECU reads the signal directly off of the CTS. If you blew the alternator, check into the fuses that are connected to the battery (MPI, etc. etc.) and also check the underhood fuse box. You could've blown one of those.
    #15
  16. 97-gst
    DSM Profiles:
    May 16, 2010
    769
    Radford, Virginia
    Its not the excessive cranking thats making it start. i can crank, and crank, and crank but no start. but as soon as i pump the gas it'll fire right up. But i'll check my CTS, fuel presure regulator, and throttle sensor.
    #16
  17. tsi1991awd
    DSM Profiles:
    Sep 28, 2008
    1,309
    4
    OK, well if you can hit the gas and it'll fire right up, then it isn't your CTS or probably anything fuel related.
    It will most likely be one of the following:
    -Boost Leak
    -ISC
    -TPS
    Because "pumping the gas" is only going to open the butterfly on the throttlebody. It won't do anything for fuel. But in opening the butterfly, it also moves the TPS, which may be adjusted incorrectly. It will also allow extra air into the motor. I say check for boost leaks then check the ISC resistance.
    #17
  18. ranman000
    ranman000 Probationary Member
    Jan 14, 2010
    15
    Chambersburg, Pennsylvania
    The same thing is happening to me only i was told by the dealer that it was a bad fuel pump, which i replaced, but its still not starting like it should.
    #18
  19. 97-gst
    DSM Profiles:
    May 16, 2010
    769
    Radford, Virginia
    yeah when i posted this thread my car had stock fuel mods. Ive since installed a walbro 255, 1050cc injectors and a AFPR and i still have to pump the gas to start my car. It definitely wasn't a boost leak either. I never did get around to replacing my ISC or TPS but idc anymore. Ive kinda gotten used to pumping the gas when i start my car
    #19
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
