Bohrn
- 1,247
- 0
- Apr 28, 2002
Chilliwack,
B.C._Canada
tons.
See if you are having bad knock and the injection takes care of it for you, you will be gaining nearly 20deg of timing advance. Thats HUGE!
Or if you don't have knock but are only running 14 psi and now you can take it to 18 psi and still have no knock, you will gain 4 psi boost pressure. And THATS huge too.
Even if you keep the same boost and have 0 knock before and after, having colder/denser air in your engine WILL make more power.
Plus it cleans your combustion chambers.
