Why is one spark plug black
Posted by dsmfreak95, Dec 18, 2009
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support JNZ Tuning
  1. dsmfreak95
    dsmfreak95 Proven Member
    DSM Profiles:
    Jun 22, 2008
    67
    jackson, Tennessee
    I was checking my spark plugs the other day and I noticed that the 3rd one( from left to right) was kind of black, and the other three looked good. I have a dynatek coil on plug set. I was wondering what's going on. I've also been haveing a problem with the car sputtering. Could the third coil be going bad or what?? Ive really only had the one the car about 8-9 months. Any help would be great. Thanks
    #1
  2. Kickerbeast
    Kickerbeast Proven Member
    Jul 21, 2009
    181
    Fort Wayne, Indiana
    Post a pic if you can. It could mean different things. Could be carbon from that cylinder running too rich, or it could be oil from leaking valve seals. A pic would help greatly. Either way, whatever is causing this is likely causing your sputtering problem
    #2
  3. 95blackGsTurbo
    95blackGsTurbo DSM Wiseman
    DSM Profiles:
    Aug 10, 2003
    3,983
    71
    Cottage Grove, Minnesota
    Since your car is sputtering, I would suggest checking compression on that cylinder, ohm out the injector and check the coil packs resistance as well. Injectors should be between 2-3ohms. If you let me know what kind of coils you are have I can get you the specs on them as well. Definitely sounds like that cylinder is misfiring for whatever reason.
    #3
  4. dsmfreak95
    DSM Profiles:
    Jun 22, 2008
    67
    jackson, Tennessee
    I'll try and post one this afternoon, I don't think it's running rich though because the plug didn't smell like gas.
    #4
  5. Kickerbeast
    Jul 21, 2009
    181
    Fort Wayne, Indiana
    doesn't have to smell like gas. If it is just a little rich it will get carbon build up. If it was rich enought to smell like gas, then it would like be completely fouled and wouldn't fire at all. Then you would have a constant miss.
    #5
  6. crimsondragon
    crimsondragon Proven Member
    DSM Profiles:
    Dec 17, 2006
    2,512
    43
    Piscataway, New_Jersey
    Was that plug properly gapped?
    #6
  7. SBR Joe
    SBR Joe Proven Member
    DSM Profiles:
    Feb 9, 2007
    1,081
    3
    Butler/Indiana, Pennsylvania
    X2. i had a headgasket pushing an ever so slight amount of water into one cylinder and the plug was black as night. Dry as a bone, just enough to blow the spark out. Could also be a sticky injector, but start with a compression test. If that cyl is lower than the other ones, you know where the problems lying then.
    #7
  8. dsmfreak95
    DSM Profiles:
    Jun 22, 2008
    67
    jackson, Tennessee
    Yea because that's the reason I took it out in the first place. I made sure they were all tapped at .028. If I were to change the spark plug out would it run better for a little while?
    #8
  9. Kickerbeast
    Jul 21, 2009
    181
    Fort Wayne, Indiana
    Depends on what exactly is causing the issue with the plug.
    #9
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
