AlwaysSunnyOhio
- 171
- 38
- Jul 6, 2014
Columbus,
Ohio
Probably in the wrong section so move if necessary.
I bought this bad joke 3 years ago. spent way too much money, had a baby, bought a house, went back to school blah blah blah.
The car is a spyder gst with a stock 6 bolt swap. I have 2 weeks to get it running or wife says it's got to go and will be parted out.
the problems:
Can't get the car to turn over with the key. Worked fine before I switched motors. Have tried 2 different starters
Can't get the car to run steady. I've had it running perfectly twice. I took the battery out to put on the charger and now it's like it's out of time. When I get it running it's super rough.
I have just about any part for the car you name it. I've tried 4 different CAS and no change. The CAS is hard wired I've cleaned the connections triple checked the wires. I've tried 2 different coils and no change. I've gone through every fuse in the car several times.
This is a stock 6 bolt the only change is a hard intake pipe, front mount intercooler and cruise control delete.
My plans this week are to drain last years gas, do a boost leak test, install DSMlink, install new spark plugs. After this I'm out of ideas.
I have every part to build a hell of a DSM. I really want to get this car running.
the problems:
