Please Support JNZ Tuning
Please Support ExtremePSI
Whiteline sway bar link rubbing axle
er82
243
28
Apr 18, 2014
Sacramento, California
For my gvr4, I installed rear whiteline sway bar and their end links on medium setting. It's a really tight fit with kyb and some unknown lowering springs. On one side the end link is rubbing against the axle bolts. When car is in the air everything is fine. Anyone had this issue before? Should I go with a stock end link or go with softer setting?
1. Can you make the end link shorter?
2. How low is your car?
I moved the link to the outer (softest) setting. It seems fine now. Car has different problems, but at least I can drive and diagnose those.
I'm not sure how whiteline intended to use the other settings. The hardest setting would put the end link at a weird angle anyhow.
They changed the design slightly and they don't fit now. I told them back when I was an engineer there but they didn't care. Get the suspension techniques bar, it actually fits.
