Which way does the oil flow? filter direction
Posted by focusedrage, May 16, 2004
Please Support Feal Suspension
  1. focusedrage
    focusedrage Proven Member
    999
    Joined Aug 3, 2002
    Laytonsville, Maryland
    I know i should know this, but i dont, so i would like to know which direction the oil flows through the filter, so that i can set up my new oil system. I have the cooler eliminator housing and hoses and what not, but im not sure which hole in said housing will the dirty hot oil flow out of. Thanks.
    Log in/Register to remove ads
  2. BUCK
    BUCK Proven Member
    2,166
    17
    Joined Dec 11, 2002
    Summerville, South Carolina
    Been a while but I'm pretty sure it flows OUT of the hole in the center of the Filter - Thru the bolt of course - TO the Engine. See my Gallery for some 1G OFH pics. :dsm:
    My DSM:
    Loading...
  3. My96AWD
    My96AWD Proven Member
    231
    Joined Aug 9, 2003
    westland, Michigan
    it would have to go the other way or the anti drainback valve would block it up.
  4. Defiant
    Defiant DSM Wiseman
    25,202
    122
    Joined Jan 13, 2003
    glorious Galt, California
    Yeh, Buck guessed wrong. And about time, I say. It flows from the outside to the inside, goes on to the rest of the engine through the center pipe.
    My DSM:
    Loading...
  5. BUCK
    BUCK Proven Member
    2,166
    17
    Joined Dec 11, 2002
    Pardon me D-Man but that's what I said.... :rolleyes:
    My DSM:
    Loading...
  6. Defiant
    Defiant DSM Wiseman
    25,202
    122
    Joined Jan 13, 2003
    Well, if what you're saying is what I mean, it sounds like you're wording it backward.
    My DSM:
    Loading...
  7. 1LE
    1LE Proven Member
    1,127
    Joined Aug 1, 2002
    Sylvania, Ohio
    Mine just flows out the bottom of the engine somewhere onto the ground :D
    My DSM:
    1995 Mitsubishi Eclipse GSX
    Rally Build
    299.9 whp   lb/ft
    Loading...
  8. Defiant
    Defiant DSM Wiseman
    25,202
    122
    Joined Jan 13, 2003
    Ah, yes. Total-loss system. I think Jaguar invented that.
    My DSM:
    Loading...
  9. focusedrage
    999
    Joined Aug 3, 2002
    thanks, i apretiat the help
  10. Black Venom
    Black Venom Proven Member
    107
    3
    Joined Sep 24, 2005
    Tampa, Florida
    The center threaded hole on the filter is the clean oil out, and the several holes are the oil inlet into the filter, correct?
    Just verifying that the oil pressure sender port on a forward facing filter housing is the clean oil.
    Thank you.
    Kris
  11. Defiant
    Defiant DSM Wiseman
    25,202
    122
    Joined Jan 13, 2003
    Yup, you're right.
    My DSM:
    Loading...
  12. Echo5Zulu
    Echo5Zulu Proven Member
    184
    Joined Jan 21, 2005
    Holland, Michigan
    I was installing my oil cooler this weekend and was thinking; which way does the oil flow through the oil filter? Is it pumped out of that center tube that you screw the filter onto? Ive been searching "How stuff works" as well as this sight and cant find anything on that specific subject.
    The reason I ask is I was just looking at the sandwich adapter and wasnt positive on the way it was supposed to go on. It was used so there arent directions but one side had a couple seals on it and the other didnt. I assume the side with the seals mates to the engine oil housing because the oil filter has its own seal and now everything is properly sealed. It looks like there is also a ball and spring style pressure relieve built in so hopefully I have it in there correctly.
    Thanks.
  13. Locke
    Locke N/T DSM Wiseman
    2,683
    12
    Joined Jan 1, 2005
    Houston, Texas
    The oil flows into the outer ring of the filter, and out the center threaded part.
    You are correct in which way to install the adaptor.
    My DSM:
    Loading...
  14. Echo5Zulu
    184
    Joined Jan 21, 2005
    Holland, Michigan
    Sweet thanks, that puts my mind at ease. One more thing though. I see some kits are like thermostat controlled or something. I dont believe mine is though. Looks like it'll just flow all the time. That shouldnt be a problem though, right?
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
