Please Support Morrison Fabrications
Please Support ExtremePSI
1G Where to find AC Comp. Belt & Tensioner
'90 GS TURBO
May 7, 2016
Apex, North_Carolina
My tensioner for the AC Compressor belt failed shredding the ac belt and in the process shifted the timing belt cover and shredded my timing belt. I need to find a Ac Compressor belt and tensioner
If you still have the pulley it's much cheaper to pull the snap rung and replace the bearing. It's a standard bearing. Nothing special. Buy a quality brand. Belt is at any auto parts store
When my pulley went bad I got the number off the side of the bearing & cross referenced to SKF bearings at Napa. They had it sitting on the shelf.
to fill y'all in on how it failed, the ac pulley bearing was worn to the point that the pulley wobbled and cut into the timing belt cover and pushed the cover into the timing belt shredding the right half but the belts in one piece.
I have a 2G and the part may not be the same & I did this years ago. All bearing have a "trade number" which is the same regardless of manufacturer & is stamped around the edge of one of the races. Once you have this number any bearing supplier should be able to find the bearing needed. Go to McMaster-Carr's website, search for bearings, & you will see how this "trader number" works. Also I just edited my original post. The brand bearing I bought was an SKF brand bearing which is a high quality bearing.
