Please Support ExtremePSI
What turbo do I have
Dsmdaniel18
Jun 12, 2018
West Valley City, Utah
I recently bought a 96 gst and I’m thinking about getting a new intercooler I’m just wondering what kind of turbo I have I saw on another post that the 96 has the t25 and I saw a intercooler that fits a TD05 I was wondering if they’re the same, if you see my post twice sorry I’m still new here took me a minute to find out how to post
That kit will definitely work, and will be completely bolt on if you contact them and let them know you're using the stock turbo (even says so in the description). The standard kit they sell assumes you've already dumped the t25 for the 14b or 16g variants that most people swap to early on.
No. They'e a different manufacturer even. T25 is a Garrett. Td06 is mitsubishi. They aren't the same.
Oh okay staying on the topic of turbos what would be a better swap a 14b or 16g or what are the pros/cons of each
One could argue pros and cons of both. I'm currently working on a GS-T conversion on my Spyder and opted to go with an Evo III 16g mainly due to cost and availability for me, while at the same time opening up larger power limits further down the road. Both are far superior to the T25 as it tends to run out of breath at the top end, this is the kind of turbo modern auto manufacturers are throwing into economy class vehicles like the Chevy Cruze (small power boost around the 2500-3000 rpm range that quickly dies out, but helps with fuel economy).
If you're looking at diving down that path, I'd highly suggest looking over the 2G DSM upgrades thread here: https://www.dsmtuners.com/threads/2g-dsm-upgrade-paths.486217/
But, do not skip over the most important part of that thread....
Okay last question, where could I get a pretty good either 14b or 16g all I’ve been seen so far that has them is ebay, also would I have to get a different manifold because I have the stock one on right now, or would that limit me from getting a aftermarket manifold down the road
Best place might be the classifieds or your local facebook listing. They are hard to find and nonexistent at this point. The ebay ones are hit or miss. They either work good or fail quick. Your manifold would work fine for either turbo as it will bolt up as stock.
Dont you have another post about this? Anyways t25 turbos are garret tdo5 turbos are Mitsubishi. So that being said there's a huge variety of tdo5 turbos because the tdo5 refers to the exhaust turbine. There's so many compressor wheels and covers. The most popular on our platform are 14b stock 1g turbos and 16g turbos that came on evo 1 through 3 and a few other mitsus that were over seas. Of those 2 the most popular covers have a pipe with 2 bolts bolted to the compressor housing for the lower intercooler pipe to attach. The stock t25 has the lower intercooler hose directly hose clamped to it.
Those are not the only 2 compressor wheels offered in the tdo5 housing there's been many different wheels that have been jammed into the 2 volt housing those are the most common styles.
There's also a down firing compressor cover. Honestly do a Google search of the 2 or post pics rather than taking the easy way out. You do not sound very knowledgeable about these cars so you really need to do some research before worrying about a fmic. Especially with a t25 which is just a waste.
Classifieds are a great place to start. @JusMX141 rebuilds turbos and just recently put a bunch up for sale.
If the classifieds don't play out, you can try a used parts vendor. Miller Import Parts always seems to have the random parts I need, if you don't see it on their website use the chat portion and send them an email. Steve Miller is typically very quick to respond.
Another vendor that I use regularly, and the one I actually bought my turbo from, is Performance Partout. Same as above, if it's not on their site, email or call them.
As for the exhaust manifold, these will both bolt right up to the stock cast-iron manifold. You may have to buy an install kit as the oil and coolant drain and feed lines may be different, but they're easy to find.
