Please Support STM Tuned
What head is this?
jlgeclipsegsx
136
Jan 4, 2011
Moorhead, Minnesota
Okay, so I purchased a head in the classifieds on here and the guy said it was out of a 96 eclipse gsx. but what i noticed is the thermostat housing doesn't fit. I have a 95 gsx. I have attached pictures. Mine is the top
The first head is a 2G head. The second is a 1G head. You can use a 1G thermostat housing on a 2G head but you cannot use a 2G thermostat housing on a 1G head.
You will also want to run a 1g intake manifold as well, the 2g im runners are much smaller than the larger 1g head runners. I ran into this issue a while ago.. the 2g mani will not work properly... just fyi
Yes 92.5-94, where 1g 7 bolt engines. And if I were choosing, I would go with the 2g head, and an evo 3 I/m of possible. Clean up and maybe a little port matching and combustion chamber cc ing and polishing. Do the oil port mod and porting before you send it to machine shop for decking and, if you haven't had it done, enlarging the head bolt holes to 12mm.
