What causes a car to shake
Posted by Bud92gsx, Mar 21, 2011
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support STM Tuned
  1. Bud92gsx
    Bud92gsx Supporting Member
    DSM Profiles:
    Jan 16, 2008
    7,814
    28
    Your moms house, BC_Canada
    Well unbalanced tires is one.
    Would tire pressure being too low cause a shaking under a certain mph?
    #1
  2. 3kgt2nv
    3kgt2nv Supporting Member
    Jan 7, 2011
    1,343
    12
    poughkeepsie, New_York
    earthquakes
    I would check to make sure all the lugnuts are tightened, also check that a caliper isnt hanging up
    #2
  3. Absit
    Absit Proven Member
    Dec 19, 2002
    2,022
    33
    Davenport, Iowa
    Just a few dozen things..
    Low tire pressure isn't one of them unless they were low for a while and developed a flat spot.
    #3
  4. Guilty1s
    Guilty1s Proven Member
    Dec 7, 2010
    103
    5
    Knoxville, Tennessee
    Wheel Bearings
    Tierods
    Broken Belt in tire
    Allignment
    #4
  5. yepes281
    yepes281 Proven Member
    DSM Profiles:
    Mar 22, 2009
    499
    H-Town, Texas
    He knows
    #5
  6. rlacasse1
    rlacasse1 Proven Member
    Jan 6, 2009
    1,827
    8
    Scott AFB, Illinois
    Under a certain mph? Is this happening when you are stopping?
    If it is then more than likely your brake rotors are shot and will need to be shaved or replaced, and new brake pads put on.
    #6
  7. Quicksilver1695
    Quicksilver1695 Proven Member
    DSM Profiles:
    Feb 3, 2009
    78
    McKeesport, Pennsylvania
    Pittsburgh roads causes major shaking. +1 on bad rotors and wheel bearings.
    #7
  8. Bud92gsx
    DSM Profiles:
    Jan 16, 2008
    7,814
    28
    under 50 mhp and no not while stopping..
    Im thinking it low tires pressure, cus they were low all winter..But I'm taking off in the morning and gonna stop and air them up, and i bet that will help..ALso putting my stock wheels back on probly wensday..I know there good n balanced..
    #8
  9. rlacasse1
    Jan 6, 2009
    1,827
    8
    Scott AFB, Illinois
    I doubt just the low pressure will cause it. Now the low pressure may have caused them to wear weird and now they are just jacked. But Just having low pressure won't make them cause a shake.
    #9
  10. Juanpa
    Juanpa Proven Member
    DSM Profiles:
    Dec 18, 2010
    61
    Ft. Lauderdale, Florida
    do you drive daily on these tires? is it really cold where you are?
    #10
  11. Bud92gsx
    DSM Profiles:
    Jan 16, 2008
    7,814
    28
    Well lets just hope it's low tire pressure, cause before winter she never shaked at all..and the tires were really low all winter..
    Not really cold..I can see grass so it's warming up..but 40's upper 40's lately..
    #11
  12. 98mitsubishigst
    98mitsubishigst Proven Member
    DSM Profiles:
    Nov 17, 2008
    917
    13
    Pittsburgh, Pennsylvania
    Why would you ask us what we think it could be if you think you know its low tire pressure... :p Sheetz or other gas stations have free or 50 cent air... Go do it now..
    But my .02 its prob not low tire pressure..
    Wheel shaking at high speeds could be alignment..
    Wheel thuds and some shaking could be tie rods and wheel bearings..
    Many different things...
    #12
  13. Bud92gsx
    DSM Profiles:
    Jan 16, 2008
    7,814
    28
    Nope no thuds..and it only shakes over 30 and under 55..otherwise it good to go.I'll pressurize the tires and see if that helps at least..
    #13
  14. 7naYRu7_rs
    7naYRu7_rs Proven Member
    DSM Profiles:
    Aug 22, 2009
    36
    Anthony, New_Mexico
    sounds like bad belts, check the tire for abnormalities by running your hand across the contact surface see if you can see bumps, if so then its a broken belt
    #14
  15. knochgoon24
    knochgoon24 DSM Wiseman
    DSM Profiles:
    4
    Jan 29, 2008
    4,737
    56
    Troy, Michigan
    Most of the suspension system can cause shaking when it wears out.
    Check:
    -Ball joints
    -Tie rod ends
    -Wheel bearings
    -Tires
    -Bushings
    -Alignment
    And I'd probably check them in that order.
    #15
  16. Mark4g63t
    Mark4g63t Proven Member
    DSM Profiles:
    Jan 21, 2010
    187
    3
    Minneapolis, Minnesota
    motor mounts
    #16
  17. 95TalonOwner
    95TalonOwner Proven Member
    DSM Profiles:
    Oct 18, 2005
    1,241
    20
    Milwaukee, Wisconsin
    Bad u joints also.
    This kind of problem is really almost impossibly to diagnose over the internet.
    #17
  18. So Cal 420a DSM
    So Cal 420a DSM Proven Member
    DSM Profiles:
    Oct 29, 2009
    37
    Oceanside, California
    Could be your motor and tranny mounts.
    #18
  19. Bud92gsx
    DSM Profiles:
    Jan 16, 2008
    7,814
    28
    FInd up the tires today, Id didn't really shake that bad till I hit 80mph, but it still wasn't that bad..Coullda ben the horrible after winter roads making sum of the problem..
    #19
  20. PanZero
    PanZero Proven Member
    Apr 16, 2010
    77
    Brazil, South_America
    My car shakes a bit between 2300-3000RPM, mostly on first and second gears. What could it be?
    #20
  21. Juanpa
    DSM Profiles:
    Dec 18, 2010
    61
    Did you ever figure out what the problem was?
    #21
  22. Bud92gsx
    DSM Profiles:
    Jan 16, 2008
    7,814
    28
    Ya when I put on the stock wheels same problem..Im thinking now it's just unbalaced wheels..And with the newely painted wheels I can see them causing shake..Gonna get them balanced in the spring..
    Wheel bearings are good,, new tie rod on one side..Ball joints I don't really know how to check that..
    I'm gonna start with getting the tires balanced..And see what's up after that...
    #22
  23. Tfitch90
    Tfitch90 Proven Member
    DSM Profiles:
    Jun 26, 2011
    302
    Bowie, Maryland
    Low tire pressure causes wear on both sides of the tire as if u had negative and positive camber at the same time. (Strange example I know) When you get wear on the tires the balance of course is different so one thing changes another.
    #23
  24. Bud92gsx
    DSM Profiles:
    Jan 16, 2008
    7,814
    28
    Allignment is up to date has about 500 miles on the allingment...The new tires on my car..I'm just gonna get them balanced..That's cheap..I think I lost a weight on one of the tires in my avitar..
    #24
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
