ThunderChild
Supporting VIP
- 3,755
- 1,140
- Jan 5, 2012
Rathdrum,
Idaho
True, i have a Welded C-diff..
I know this is steering away from this thread, but how does that make any sence, if the VC is at the very end of tranny, how does replacing it do anything since there is no shaft connected to it. ?
Idk what you mean by replacing I guess. If you mean swapping for the eliminator, then it does the same thing as welding the center diff. It locks the front drive output and tcase output together. The tcase input shaft is splined to the center diffs spider gears, and normally has the viscous coupler connected to both pieces, allowing a certain amount of slip.
