Please Support Rix Racing
Please Support ExtremePSI
1G Weird "in dash" noise
enriquez2000
2,277
820
Oct 5, 2014
fort collins, Colorado
This is going to sound weird but when i first start driving it almost sounds like alternator belt slipping but in dash... not as loud onviously but a definite squeak. It also only happens while moving. Once car is warmer it will go away completely for the most part.
Cant seem to figure this one out.
you may have to turn volume up but here it is.. it stops when I stop and gets a bit faster when I do and then goes away after I drive for about 20min or so...
U might be able to spray a little wd 40 inside the cable if that is whats squeeking or buy a new one for 40 bucks. If its the cluster better off just getting another used one since i wouldnt want to spray wd40 in my cluster LOL
If its the cluster ill mad it to something like this
Youll have to use a 2g vehicle speed sensor for the digital speedo. Not too hard but basically you got to wire it in yourself.
Easy to do.. ive used gps sensors for speedo too. Im hoping that I can just replace the speedo cable to fix the issue. for now I can handle the hamster wheel until it goes away but it will eventually crap out
