water pump pulley shaking
Posted by rab, Jun 19, 2003
Please Support JNZ Tuning
  1. rab
    rab Proven Member
    41
    Joined Jun 16, 2003
    o.k. i bought a 1990 talon turbo for a good deal my first dsm and i'm not familyear with these cars at all.
    my ? is the water pump pulley in shacking when at idle or maybe even when it accelerating just not sure havin check yet, has anyone had this problem before or maybe is this a common problem?
    also can i remove the water pump pulley buy just taking off the 4 nuts on the pulley or will i have to remove the hole unit and then use a pulley puller tool cause i really don;t want to mess with taking all that other stuff off to get at the pump.
    Log in/Register to remove ads
  2. DSMRevolution
    DSMRevolution Proven Member
    707
    10
    Joined Dec 6, 2002
    Sioux Falls, South Dakota
    You can remove the pully by just removing the 4 bolts that go into the WP assembly through the pully. The wobble could just be a bent pully (easy to replace) or a few loose bolts. I doubt its the pump that would be bent or wobbling unless the bearings are going out in the WP (water pump). Does your water pump leak at all?
    My DSM:
    Loading...
  3. rab
    rab Proven Member
    41
    Joined Jun 16, 2003
    no the water pump don't leak. thanks for the answer that's what i thought too and i'm very happy i can get it off just buy taking those 4 nuts off, man i really happy.
    thanks ryan
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
