EclipseLunar
- 1
- Sep 7, 2012
Beaver Dam,
Wisconsin
What would cause the water pump to leak under boost? Whenever I boost to much coolant around the timing belt area will leak and smoke will come out of timing belt cover? Also when at idle it will overheat and leak after 5 mins. When driving normal i haven't notice it leaking at all, then i park and there is maybe a little coolant puddle under timing belt area. New water pump was installed maybe about 8,000 miles ago. Leaked when first installed thought it was the ring still sealing. What do you guys think?
