Inkdlyfe
- 438
- 7
- Feb 23, 2016
Summer feild,
Florida
Alright so i got the opportunity to take what i wanted off this abandoned 2g 4g63 eclipse sadly motor was shot but there was many many upgrades im still working on getting off most i was familiar with but i came across this thing hidden pretty damn well but the red and black wires have been cut and the two openings have nothing to them reads this " alcohol injection system DDP5800 open flow 1.0 gpm by pass 200 psi volt 12 vdc current 10.0 amps at 200 psi" i done some research on these systems and it seems to be only turbo charge engines my engine currently is not turbo but will be here soon now installing this should i wait or can i do it now ? the engine is fully built only thing stock is my cams, i seen how to put your own system together with out this capacitor looking thing using a window wash pump found in any type of car but i wanna use this one but dont want to over do this. i was thinking maybe using a injector as the fitting ? would that work ? or what should i use ?
