Bo0sTeD 4G63
- 469
- 78
- Aug 31, 2008
Miami,
Florida
I am converting my car from FWD to AWD but the problem I am having is when I put the car in reverse for some reason the tires spin forward. I am using the kiggly mod also, I have checked to make sure the solenoids are good, and I also checked to make sure my transmission pump works. I have no reverse the only thing the transmission does is when the car is in reverse it looks like its on 2nd and when I put it in neutral it looks like it goes into low gear. Also when I hit the gas the wheels do not spin any faster they stay rotating at the same speed even though the rpms are going up. I don't know if maybe the transmission is in limp mode or maybe something else is wrong that can be an easy fix. I just wanted to know if there is anything else I can try before I take out the transmission.
