2G VRSF J Pipe Install
Posted by RevyDSM, Apr 20, 2017
Please Support Kiggly Racing
  1. RevyDSM
    RevyDSM Probationary Member
    29
    Joined Apr 16, 2016
    Dayton, Ohio
    My Front mount came today and I'm having a hard time installing the j pipe. The left screw goes in just fine. However the right screw is a pain in the ass. You can't fit a single tool inside to get it tight or even to thread in. Yes I know the picture was taken with the wrong bolts but now I'm using the old J pipe bolts.
    Log in/Register to remove ads
    My DSM:
    1998 Mitsubishi Eclipse GST
    Street Build
    50trim   manual
    Loading...
    ErikTande likes this.
  2. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    2,682
    772
    Joined Nov 14, 2013
    Independence, Kansas
    Get allen head bolts. They will be much friendlier :) With the VRSF J-pipe you have to start one of them first, the inside one.
    Ps. Same thing on TPS screws. :)
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
    14b   automatic
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 MPH
    13.612 @ 107.760 MPH
    Loading...
  3. RevyDSM
    29
    Joined Apr 16, 2016
    Dayton, Ohio
    I'm using the old Allen head bolts I was having trouble getting off.
    My DSM:
    Street Build
    50trim   manual
    Loading...
  4. 1990TSIAWDTALON
    2,682
    772
    Joined Nov 14, 2013
    Recheck the tightness after a heat cycle or two. Shud be good to go then but check them periodically. :thumb:
    My DSM:
    Street Build
    14b   automatic
    Loading...
  5. RevyDSM
    29
    Joined Apr 16, 2016
    Dayton, Ohio
    Only problem is one of them is impossible to get to go in due to the stupid design of the j pipe
    My DSM:
    Street Build
    50trim   manual
    Loading...
  6. 1990TSIAWDTALON
    2,682
    772
    Joined Nov 14, 2013
    Show me
    Show me a picture. I have a VRSF kit. But I am now HX40. Started out with that setup tho.
    My DSM:
    Street Build
    14b   automatic
    Loading...
  7. RevyDSM
    29
    Joined Apr 16, 2016
    Dayton, Ohio
    My DSM:
    Street Build
    50trim   manual
    Loading...
  8. 1990TSIAWDTALON
    2,682
    772
    Joined Nov 14, 2013
    Ok. I had to hold the j-pipe out as far as possible then engage a thread and keep threading it down by hand if possible. Use anti-sieze. It helps going in and back out. Do u need to dimpel the tube at the flandge just a tweak? Gotta MAKE things work some times but its a good kit, I still run it.
    My DSM:
    Street Build
    14b   automatic
    Loading...
  9. 1990TSIAWDTALON
    2,682
    772
    Joined Nov 14, 2013
    Yep I see...start the other allen head bolt first or use THAT bolt on the inside and hold the pipe out so the threads just catch on it and keep threading in as far as possible by hand then ya gotta sacrifice a pawn shop allen key and shorten it some so you can tighten it. I make A LOT of "custom" tools just for my DSM. :aha:
    My DSM:
    Street Build
    14b   automatic
    Loading...
  10. 1990TSIAWDTALON
    2,682
    772
    Joined Nov 14, 2013
    Hey sometimes you have to grind the allen bolt head down a bit to get it to go in.
    My DSM:
    Street Build
    14b   automatic
    Loading...
  11. boostdawd
    boostdawd Proven Member
    1,000
    255
    Joined Apr 6, 2010
    phoenix, Arizona
    Yup. Frustrating when u have to remove and reinstall. The design of the j pipe is flawed. U need to screw the bolt on the right first. Push it in the j pipe before u begin to bolt it down.
    My DSM:
    1991 Eagle Talon TSi AWD
    Drag Race Build
    GT35   manual
    1992 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    Loading...
    1990TSIAWDTALON likes this.
  12. 1990TSIAWDTALON
    2,682
    772
    Joined Nov 14, 2013
    Thats the trick!!! I wonder why the hell they dont include a simple pc of paper saying that for customer freindliness :idontknow:
    My DSM:
    Street Build
    14b   automatic
    Loading...
  13. Tanro
    Tanro Proven Member
    1,413
    47
    Joined Jul 22, 2009
    Hanceville, Alabama
    I use a hammer and a chisel on the edge of the bolt. Have to do it with the bottom right bolt on the tb elbow too.
    Just use a cold chisel, and tap towards one of the points on the bolt head. Its pretty sh**ty way to do it, but no clearance to get a wrench on there in some cases.
    An allen head and a Long ball end allen head socket works good too. Or long ball end t-handle if you can't get, or dont want to spend the cash on long ball end allen sockets. I know my snap-on set of long allen and long ball end allen was like 160$ or something... and that was on sale.
    My DSM:
    1999 Mitsubishi Eclipse GST
    Street Build
    16g   manual
    Loading...
  14. ErikTande
    ErikTande Supporting Member
    708
    142
    Joined Dec 17, 2012
    Centennial, Colorado
    Yep, they're a PAIN in the ass. I got longer bolts and stacked a bunch of washers on mine which made it a little easier, but not much. The design of the jpipe makes the bolts want to go in cross threaded every time. Like others here have said, there's a few tricks that can help a little, but basically just be prepared to be frustrated every time you put it on. It should take about 3 minutes, it usually took me 15 to 20, swearing and getting pissed the whole time :p
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory
