VHT flameproof ceramic paint
Posted by 92_talonGsXt, Apr 10, 2009
Appearance/Interior/Exterior - All interior and exterior tech discussions; body and paint, conversions, lighting, washing, waxing, etc.
Please Support Ace Race Parts
  1. 92_talonGsXt
    92_talonGsXt Proven Member
    Jan 1, 2009
    113
    lake forest, California
    Has anyone used Vht flameproof ceramic coating rated at 2000 degrees?I just picked up an evo 3 manifold and wanted to get it coated,any one have experience with Vht flameproof ceramic paint
    #1
  2. nightracer91
    nightracer91 Supporting Member
    DSM Profiles:
    Feb 27, 2006
    363
    4
    Fort Wayne, Indiana
    Great stuff!! I used it on my manifold, tubine housing, o2 housing, and downpipe. Very impressed with it. My buddy used it on his Turbo MR2 and had great results. Just be sure to follow the directions on the can very carefully! Bake and let cool as directed.
    #2
  3. AWD_Hybrid
    AWD_Hybrid Proven Member
    Apr 1, 2009
    174
    Sydney, Australia
    If you plan to spray smoothe surfaces, get the surface industrial beed
    blasted, rather than only a light sand blast. Coating will hang on better.
    Cheers !
    #3
  4. tjbiker031
    tjbiker031 Proven Member
    DSM Profiles:
    May 4, 2007
    382
    Bradenton, Florida
    Never used it personally, but heard its great.
    #4
  5. ApexVIII
    ApexVIII Proven Member
    Jan 12, 2008
    711
    Modesto, California
    i have it on my hotside and o2 housing sofar so good!!
    #5
  6. architechnik
    architechnik Proven Member
    DSM Profiles:
    Jun 21, 2007
    609
    5
    Glad, Oregon
    I just did my entire exhaust side, from manifold to muffler, while installing my new setup... We'll see how it all holds up.
    #6
  7. toofast82
    toofast82 Proven Member
    Feb 8, 2005
    2,614
    10
    Tinley Park, Illinois
    I just installed a evo3 manifold, 7cm turbine housing, and 2.5" O2 housing that i primed and painted with the VHT 2k* ceramic. Everything looked very nice before install. I even baked per instructions off the car and its wearing off quickly with less than 150miles. Don't waste your time.
    #7
  8. 1gcrazy
    1gcrazy Proven Member
    DSM Profiles:
    Apr 6, 2005
    930
    5
    Fountain, Colorado
    What did you "prime" this with?
    #8
  9. toofast82
    Feb 8, 2005
    2,614
    10
    VHT Flameproof primer 2000* which they recommend using on the ceramic coat directions. I do seem to notice a difference in underhood temps though.
    #9
  10. nightracer91
    DSM Profiles:
    Feb 27, 2006
    363
    4
    Fort Wayne, Indiana
    Did you clean all of your surfaces properly and apply more then just on coat? I did 3 coats on mine and 1500 miles later it's still looking good and keeping temps down.
    #10
  11. InfiniteGSX
    InfiniteGSX Proven Member
    DSM Profiles:
    Dec 10, 2002
    2,473
    10
    Tijeras, New_Mexico
    I used black on my Turbine Exhaust Housing, O2 Housing and 2G Manifold. Liked it.
    [​IMG]
    Just don't touch it, it likes finger prints... as you can tell LOL.
    #11
  12. jdodds
    jdodds Proven Member
    Mar 11, 2008
    322
    Pleasant Grove, Utah
    I used that stuff and it cooked off after a spirited drive. I had a pretty bad tune on it so Im sure that had something to do with it. The manifold was glowing red and turned white after it cooled down.
    #12
  13. TurboTsiThatFly
    TurboTsiThatFly Proven Member
    DSM Profiles:
    Sep 9, 2007
    298
    Randleman, North_Carolina
    did you let it bake the full 30mins on the 3 different heat levels?:hmm:
    #13
  14. Reject
    Reject Proven Member
    Feb 27, 2009
    73
    Saint Paul, Minnesota
    Used it on my exhuast manifold when I replaced it. Used aircraft cleaner to prep it after doing a 300 grit rough up, 5 coats of VHT and >500 miles later it was baked off... Maybe it was user error... Just my personal experiance...
    #14
  15. Torch1
    Torch1 Probationary Member
    Apr 24, 2009
    13
    Bentonville, Arkansas
    used it on my exhaust manifold as well. i highly recommend it.
    #15
  16. My1GLaser
    My1GLaser Proven Member
    DSM Profiles:
    Dec 4, 2006
    1,424
    18
    Bartow, Florida
    I didn't have the best results doing the on car curing method. It is still "blackish" after a couple thousand miles, but not the best looking. I didn't prep and it was still rusted, so I guess not too bad overall.
    However, I am doing my homemade O2 housing with it this weekend and plan on sandblasting and doing a few coats so I am sure it will turn out better.
    #16
  17. Bud92gsx
    Bud92gsx Supporting Member
    DSM Profiles:
    Jan 16, 2008
    7,814
    27
    Your moms house, BC_Canada
    I used this stuff too..I prepped vertty heavily..I would highly reccomend it...So would a couple other buddies of mine..The $9.00 a can is really worth it..
    #17
  18. TurboTsiThatFly
    DSM Profiles:
    Sep 9, 2007
    298
    have any of you guys used it on your heat shields? and if so did you let the heat shields bake for the full 30 mins? :talon: :hmm:
    #18
  19. DougR
    DougR Proven Member
    Aug 23, 2007
    338
    3
    Houston, Texas
    Kinda off topic, But I use the coating on everything..
    Especially ATV pipes. If prepped properly as directed, it holds rather nice. Even when going from red hot to ice cold in seconds. As in being dunked in a mudhole or creek.
    Last coating got it Really thick and then wrapped in header tape. Even sprayed the tape with high temp silicone paint, the stuff works GREAT! for reducing temps. Im no longer scared of burning my leg off from a uncoverd exhaust pipe.
    #19
  20. TurboTsiThatFly
    DSM Profiles:
    Sep 9, 2007
    298
    Have you used it on your dsm for anything?? how did it workk for you on your dsm if you have used it? :talon: :hmm:
    #20
  21. Bud92gsx
    DSM Profiles:
    Jan 16, 2008
    7,814
    27
    #21
  22. Kyle_T
    Kyle_T Proven Member
    DSM Profiles:
    Oct 19, 2008
    586
    9
    Muskego, Wisconsin
    sorry to dig this thread up from the grave, but im looking at using this on my manifold, tubular o2 housing and maybe the hotside of my turbo. Does this coating retain heat like a headerwrap or like a ceramic coating or what?
    #22
  23. Bud92gsx
    DSM Profiles:
    Jan 16, 2008
    7,814
    27
    Ceramic coating actually keeps the heat out..Once you put the stuff on and bake it, It does keep the temp down big time..You can actually put your hand like an inch away and almost feel no heat...I'm sure 90 percent of the dsm tuner audiance would reccomend ceramic coating..Buying the can is the really cheap way to get it done and doesn't help as much as sending it out to be coated inside and out, but also keeps the cost to about 10 bux...Instead of paying 30+ to get it coated..Sending it out is the ultimate ceramic coating, but for 10 bux you really can't go wrong..
    Contrary to popular beleif, header wrap just traps the heat in the manifold, and eventually might cause cracking, due to the heat retention of the wrap..Ceramic has the opposite effect..And makes you able to almost touch what was coated..
    #23
  24. 4g63t
    4g63t Proven Member
    DSM Profiles:
    Aug 14, 2005
    823
    7
    North Iowa, Iowa
    I want to do this on a Tubular manifold. Anyone done this? hmm
    #24
  25. cloead
    cloead Proven Member
    Jan 22, 2005
    102
    Cleveland, Ohio
    comes out like this if you prep good:
    [​IMG]
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
