Calan
DSM Wiseman
- 7,251
- 363
- Jan 16, 2007
OKC,
Oklahoma
Has anyone else noticed a dip in the VE at around 3500 rpm (specifically on a stroker, but on any setup in general)?
No matter what I've tried to do with smoothing and manipulating values on either side, the VE at 3500 rpm has always been lower than I would expect, and the VE at 2500 rpm much higher...even on different turbos, intake, etc. I also see a similar dip at 2000 rpms and very low loads, but not as much.
It doesn't matter if I run the CombinedFT wizard in link, or do the math by hand and adjust them all manually at various points. IAT's, type of fuel, and coolant temps also have no effect on it. I always get the same results.
Any idea why? What would cause an rpm-dependent restriction at low loads like that?
