Please Support STM Tuned
Please Support ExtremePSI
2G Vacuum Caps
PrimerPLus
1,158
20
Jul 28, 2011
Tokyo, Asia
Anyone know where I can get a set of high temperature vacuum caps? (probably needs to be silicone?)
I have had to replace my current vacuum caps a few times because they just crack. They are from Schucks, and I think it's because they are the rubber ones.
If anyone knows a good kit that comes with assorted sizes or if anyone knows the sized that are required to cap all the ports on the throttle body and the Intake Manifold / Valve cover PCV ports.
Why not remove the unwanted nipples (heat is your friend), tap the holes and plug them with some set screws? No need for cheap caps ever again.
I,haven't ill,check them out thank you cbyamd.
Do you mean like napa?
I like to keep it so if I have to convert it back it won't be a pain. Otherwise yah I'd do that biglady112
I do like I did. Weld them shut.
If you tap the holes and install set screws make sure to use cement to seal them and to make sure the never come out.
