forcefed86
- 1,007
- 12
- May 23, 2006
wichita,
Kansas
With the crazy fuel system demands of E85 I was just wondering if pump E85 70-85% ethanol is really necessary? I've seen 1500+hp engines out there running 85% methanol. Few of them local at our drag strip. It seems no one is having trouble with detonation on this fuel at reasonable power/timing levels.
I'm finishing an HX-40 setup at the moment and the thought of running huge injectors and re-vamping the whole fuel system rubs me the wrong way. Currently run factory lines/filter with a TT supra fuel pump and 1000cc injs. Unfortunately they don't have e50 at the pumps here. As I believe that would be the perfect mix for my 500-550hp goals.
I'm wondering how far I can push E30. You never hear anything about the lesser blends. Would be a huge advantage if we could squeak by with e30 over e85 though.
Run single wally 255 or similar with out fear of it falling short.
Could run reasonable sized injectors for great driveability
Retain the factory fuel line setup
pick up gas mileage
lower blends never change ehtanol percentages (easy tuning)
Just a thought... anyone running e30 out there? I may end up trying it out. I'm tired of the crappo mileage anyway.
pick up gas mileage
