1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
UR Evo Crank and Accessory Pulleys
Posted by unorthodox, Apr 16, 2018
Please Support Boostin Performance
  1. unorthodox
    unorthodox Supporting Vendor
    6
    25
    Joined Oct 30, 2009
    Gainesville, Georgia
    The next new crank pulley and accessory pulleys are for the Evo V thru IX. The crank pulley is part# CS981, the alternator pulley is part#AS981 and the water pump pulley is WS981.
    The stock crank pulley weighs in at a fairly meaty 3.7 lbs for a single 6 rib belt. This Nano-lite stock diameter version weigh in at a svelte .6 lbs. The reduction of rotational weight is over 95%.
    The stock diameter alternator pulley weighs .43 lbs and the new alternator pulley weighs .008 lbs.
    The stock diameter water pump pulley weighs 1 lb and the new nano-lite version weighs .39 lbs. The outer diameter of this pulley has 3 mil black hardcoat plating to eliminate the potential for wear as the rougher back side of the belt rides this pulley.
    We can make these new versions or any version this community might want with as little as a 10 piece group commitment per version.
    All together these pulleys reduce rotational mass by over 98%.
    When we first made the underdrive version of this crank pulley our great friends down at Alamo Autosports ran some before after dyno testing on their stock Evo VIII (1 week in between for ECU learning).
    Quantity - Price Breakdown
    Alternator Pulley (AS981)
    10-19 $100
    20-29 $80
    30+ $70
    Crank Pulley (CS981)
    10-19 $210
    20-29 $190
    30+ $180
    Water Pump Pulley (WS981)
    10-19 $150
    20-29 $130
    30+ $120
    Log in/Register to remove ads
    Featured Products from our Supporting Vendors
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
