Upper radiator hose high pressure
Posted by slickonice, Mar 7, 2010
  1. slickonice
    slickonice Probationary Member
    20
    Joined Feb 22, 2009
    new orleans, Louisiana
    So after driving my gsx around tonight i noticed a bit of steam coming from the hood. I checked it out and it looks to be my overflow bottle. It's been getting more full of coolant every time i look at it. And my upper radiator hose is hard as a rock and bloated like a pig. It has a 13 psi radiator cap from auto zone.
    I was reading and people were saying its probably the head gasket. My coolant looks fine and the oil isn't milky or anything. Could the thermostat be the issue?
    Thanks!
    Log in/Register to remove ads
  2. turbotalon31
    turbotalon31 Proven Member
    291
    3
    Joined Jan 9, 2010
    reading, Pennsylvania
    does the lower radiator hose get hot ?
    My DSM:
    Loading...
  3. YENKO
    YENKO Probationary Member
    4
    Joined Mar 6, 2010
    MEXICO, Central America
    does the UPER radiator hose get hot ? IF IT DOESNT YOU COULD HAVE A BAD THERMOSTAT, BROKEN WATER PUMP OR CLOGGED RADIATOR
    AND IF IT DOES GET HOT, THE MOST PROBABLE THING IS THAT YOUR RADIATOR CAP IS NOT WORKING LIKE IT SHOULD, INSPECT THE GASKETS OF THE CAP THAT GO INTO THE RADIATOR.
  4. dsmkidd20
    dsmkidd20 Proven Member
    57
    Joined Feb 11, 2010
    taunton, Massachusetts
    Well just get a new thermastat and coolant temp sensor they are both like $15 or less at autozone, both are a cheap and easy fix, try that first.
    Loading...
  5. jay-red
    jay-red Proven Member
    81
    4
    Joined Dec 11, 2009
    sacramento, California
    are you overheating at all?
  6. slickonice
    20
    Joined Feb 22, 2009
    okay thanks, i'll run to auto zone tomorrow. I'm not overheating at all. The upper radiator hose gets hot to the touch. I didn't check the lower one though
  7. turbotalon31
    291
    3
    Joined Jan 9, 2010
    check the lower 1 if its not hot try a new rad. cap and thermostat and not all bad headgaskets leak into the oil some leak external best way to find out is a compression test
    My DSM:
    Loading...
  8. velocitysport31
    velocitysport31 Proven Member
    158
    Joined Feb 19, 2009
    Oak Hills, California
    Coolant temp sensor has nothing to do with your problem...so dont wast your money on one. Pull your thermostat put it in boiling water make sure it opens and closes. If it doesn't that could be your problem. If it does then you might have issues somewhere else. A blown head gasket doesn't always mix oil and coolant, It could be blown and pushing coolant. You could also have air in your system also. A bad radiator cap could also cause the same issues you are having.
  9. slickonice
    20
    Joined Feb 22, 2009
    Another thing, my overflow bottle got burned a while back and the cap doesn't really seat or seal, it just kinda sits on top. That wouldn't cause problems, would it? And I just took my car for a drive and when I get back checked the radiator hoses. Top one is hot and puffy and lower one isn't nearly as hot.
  10. velocitysport31
    158
    Joined Feb 19, 2009
    I dont think your coolant bottle would cause your issues, Check your thermostat
  11. 4g63thermal
    4g63thermal Proven Member
    52
    Joined Aug 18, 2007
    Bethlehem, Pennsylvania
    high pressure in the upper hose could be a thermostat try testing it like stated earlier in boiling water
  12. slickonice
    20
    Joined Feb 22, 2009
    okay, i'll pull it out and test in boiling water. Thanks for all the input!!
  13. turbotalon31
    291
    3
    Joined Jan 9, 2010
    just buy a new radiator and cap both cheap and will probably solve ## issue
    My DSM:
    Loading...
  14. 4g63thermal
    52
    Joined Aug 18, 2007
    did you mean thermostat?
  15. slickonice
    20
    Joined Feb 22, 2009
    The radiator is an aluminum mishimoto with about 2 months on it. I'll pick up a new cap in the morning, hopefully that does it.
  16. 4g63thermal
    52
    Joined Aug 18, 2007
    i dont think you need a new radiator
  17. dsmkidd20
    57
    Joined Feb 11, 2010
    Does your car blow smoke out the exhaust?
    Loading...
  18. turbotalon31
    291
    3
    Joined Jan 9, 2010
    yeah i ment thermostat and radiator cap sorry its like 1 in the morning here
    My DSM:
    Loading...
  19. DSM1G90
    DSM1G90 Supporting Member
    4,830
    54
    Joined Apr 6, 2008
    Nampa, Idaho
    Stay away from "Autosh**zone" junk! Get you a better cap from NAPA or similar.
    I had the same problem happened last summer and outside of a cap that went bad, I did a system flush with taking out the radiator and flushing the crud out of that thing along with flushing out the heater core before I restored my system. I got a 13lb cap from NAPA and my system is back to normal.
    Loading...
  20. slickonice
    20
    Joined Feb 22, 2009
    okay well today I replaced the radiator cap and the thermostat. The old thermostat was pretty crusty and I couldnt get it to open up with boiling water. It seems like this helped, the hose doesn't look as bloated anymore.
  21. nuclearr
    nuclearr Proven Member
    1,201
    11
    Joined Jun 22, 2004
    Slidell, Louisiana
    Since the hose swelled up I would recomend replacing it before it bursts. They strecthing of it has probably caused it to be weaker. They should only well slightly when hot.
    My DSM:
    1996 Mitsubishi Eclipse Spyder GST
    Street Build
      manual
    Loading...
  22. slickonice
    20
    Joined Feb 22, 2009
    okay cool, i'll pick up another one tomorrow
  23. 4g63thermal
    52
    Joined Aug 18, 2007
    +1 about the hose but glad you got everything else working properly
  24. xhackerekx
    xhackerekx Proven Member
    270
    Joined Jan 1, 2009
    UE/Scranton, Pennsylvania
    +1 for thermostat.
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
