DSMNOB
- 1
- Jul 7, 2016
Meridian,
Idaho
First of all, I have searched and searched and my misfire issues seem to be more specific than I can find. I found a few posts/threads that have similar problems, but the threads just die...
Details:
-The misfire happens every time while cruising between 2.5k to 3k RPMs, but only while cruising. Not during WOT or any other fluctuation of throttle. I can prevent it from happening while cruising by fluctuating the throttle.
-It does NOT recover by sticking the clutch in and/or letting off the gas. I have to turn the car off and on for the misfire to go away.
-AFRs are perfect when misfire happens
-Tried two different 1g cas
-Timing was just done.
-New plugs
-Tested plug wires and getting great spark
-It is a 96+ ECU with a 2g v3 DSMLink.
Here is the kicker..
I was on AEM EMS v1 and did NOT have any issues with misfire... I just switched over to DSMlink and now I'm having misfire issues.
No, disabling misfire checks under the DTC tab will not solve my issue because it is a unrecoverable misfire.
Any advice or direction would be appreciated!
Details:
-New plugs
