Wildwomper
- 1
- Mar 31, 2018
Houston,
Texas
Hello all, I recently purchased a socketed eprom ecu and I want to get this figured out before it comes in. It has four vertical boards in it which based on my research it proves to be a 90 along with the code along the plug section, but the seller tells me it’s coming out of a 92. So I’m assuming the previous owner of the car which is being parted out, pinned his harness to work with the 90 ecu. But that’s not my main concern, what im wondering is that from the looks of it it doesn’t have a stock mitsu eprom chip in it. You will see in the pictures above that it has a chip with some numbers and words and an injector code on the top but there is a spot missing from the sticker so I can’t make out the rest. I’m wondering if anyone knows of any other tuning software that this could potentially be, being this is not link v2 or v3 and v1 wasn’t available for 1g’s. I appreciate your help in advance. Also he said it has a cable which I have also included a picture of as well.
