NewClipse96
- 89
- 0
- Apr 26, 2011
kissimmee,
Florida
Im sending my head to a machine shop to be redone does anyone know about how much it would cost to have done just curious?!
Note: This feature currently requires accessing the site using the built-in Safari browser.
there redoing all my valves an all idk exactly i just no to ylinders valves got bent when my timing belt popped
'97boostinGST..... what is it you want to do with the 2 valves? install them? cut them down to std size?
sorry for the thread jack......
yes!! replace the valves!! put the STD ones in, and hope the shop did not use the os valve when they did the valve job.
If the shop used the os valve when they patterned in the seat for the valve job then you will need the os valves to fix it.
lap a valve or two on both the int and exh side, the seat should be centered on the valve, if it is running off the outer edge of the valve the seats are too big and will need the OS valves installed.
if you lap the OS valve in on a std seat the seat will be on the inside of the valve face(towards the valve stem)
you do need to check this out before the head is installed!
http://www.dsmtuners.com/forums/art...ve.[/QUOTE]Great! Thanks for the info.
