UCF201101
- 93
- 0
- Sep 11, 2011
Ocala,
Florida
I have a 1999 Mitsubishi eclipse gs that is the Ozzy edition. I have no clue to what type of transmission it has it in. I have a metal plate that reads:k91537469009. I am trying to fix a transmission leak. I replaced the torque converter seal with no new results. I decided that has to be the flywheel being bent or the torque converter being bad. I noticed on the shaft that it was polished...as to where the seal had been rubbing. I did not think this would cause the seal to leak so now that I did all that work for nothing I decided to replace it. If anyone can identify the type of transmission or point to the direction as to where I can obtain the correct info. Thank you guys in an advance...
